1998 Honda Civic Cranks but won't start!!!
Old 12-05-2013, 10:46 AM
davidzhou4893's Avatar
Icon6 1998 Honda Civic Cranks but won't start!!!
When i brought the car it ran good for about a week then it started to bog. Then i got it fix and ran good for another week then it happened again. Now the car bogs when it starts up, but recently it haven't start up it only cranks. The things I changed spark plugs, added helicoils for two cylinders, spark plug wires, fuel filter, fuel pump, ignition coil, thermal for fan that cools off the motor, oil change and that's all I could think of. Been spending a lot of money and the car still only cranks with no start. I have no idea where to start off to check for the issues/problems.
Old 12-05-2013, 10:50 AM
B_Swapped93's Avatar
Default Re: 1998 Honda Civic Cranks but won't start!!!
helicoils ? confirm fuel then mechanical timing check that you're getting spark also even to you've replaced a **** load of ignition components.
Old 12-05-2013, 11:17 AM
Helicoil spark plug thread repair kit https://encrypted-tbn3.gstatic.com/s...iYTvY&usqp=CAY
Alright thanks man I'll get it check and I'll let you know.
Old 12-05-2013, 12:42 PM
hardcore97's Avatar
you need to verify that you are getting fuel and spark. start with the simple things
Old 12-12-2013, 07:49 AM
So I brought the OBD2 scanner and scanned it, no codes came up. I also used starting fluid and sprayed where the air sensor is and still only cranks. I checked if there was fuel pressure by untightening the screw on the fuel rail and fuel sprayed out.
Old 12-12-2013, 08:03 AM
pityocamptes's Avatar
Have you checked mechanical AND ignition timing?
Old 12-14-2013, 10:36 AM
How do I check for mechanical and ignition timing?
Old 12-14-2013, 12:13 PM
please google^ will be the first thing that comes up
Old 12-14-2013, 02:34 PM
Vladglad's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-do-you-check-mechanical-timing-compression-2497191/
Old 12-28-2013, 05:43 AM
Alright so I did not check anything but yesterday I just cranked the car like 3 times and it started up so what would be the problem now?
Old 03-18-2014, 08:53 AM
Problem solved it was my distributor rotor that was burned out.
quad
20
03-14-2007 05:16 AM
oakpwr
01-20-2007 06:00 PM
nylshatch
11-28-2005 06:29 PM
pistol
10-07-2003 08:56 AM
Quick Reply: 1998 Honda Civic Cranks but won't start!!!
