94 del sol won't start, it cranks but won't stay on
Hey guys I got a 94 del sol with a d16 in it and it won't start it cranks but won't stay on I replaced the main relay and also the ignition switch and I still get the same problem wat can it be.??
Shit Posts: 15
Re: I need help!!!!!!
Check to see if your fuel pump primes.
No? Check fuel pump. Yes look below.
Pull out spark plug wire and attach plug. and have someone crank it, hold plug near ground and look for spark.
Ohm spark wires and check all plugs and distributor.
Test fuel injectors. 10-13 ohms is the spec.
Check fuel injector connecters with volt meter while someone cranks the car.
Finally check compression in all cylinders.
If compression is below 80, adjust valves or either your rings or valve seats are bad.
JesusGLS
01-13-2013 04:59 AM
