D16z6 Squealing noise coming from crank pulley area
Car: 94 Honda Civic DX auto
Engine: d16z6
I'm having some squealing noise coming from the crank pulley area.
I removed the belts from the alternator, power steering pump and AC compressor To eliminate any of those as the cause of the problem. I did a little research and I'm going to check the keyway and the crank bolt tomorrow. I was just wondering If anyone had any other ideas to look for or had a similar problem.
Short clip of the sound
Engine: d16z6
Re: D16z6 Squealing noise coming from crank pulley area
Definitely get that crank pulley off of there and check it out. Another answer might be to remove the upper timing cover and check to see if its something within the timing system.
I did not change the timing belt. I owned the car the engine came out of, It ran fine when I removed it. It sat for about a year before I did the swap.
I know that this engine ran fine before when it was in a crx but the only difference was that it had a manual trans attached. Do you think this noise could be caused by something in the automatic trans?
longlivekel1
19
04-06-2010 05:59 PM
