B18 with GSR or B16 Trans??
2000 coupe with b18 and ls trans looking to get a new trans have two to pick from looking to 1/4 track the car n/a. My choices are a S4 (si trans) or a Y80/S80 (gsr trans) both USDM. Found my research everyone says b16 tranny and possible differental upgrade later because weaker diffs.. My question short distance 1/4 mile which would be better??
A friend and I both have the same setup he though has a gsr tranny and I am stuck with the slow ls tranny he beats me every time I'm hoping to pull ahead by making a better choice with which trans I buy
Thanks HT Guys!
Thanks HT Guys!
Re: B18 with GSR or B16 Trans??
s4c b16 jdm trans has dual synchro's an LSD.
anyway b16 usdm si has a little closer ratios than usdm gsr i think both has same final drive 4.4.
personally I like the my ITR which is basically a b16 lsd trans. it SUCKS to do any highway driving but I do not drive much if ever on highway so its ok for me. I like the fact I can cruise around town in 5th and still be at 2.3/2.5k rpms and have tq to pull in traffic if needed
np. btw I drive 11 miles one way to work on a 50mph county highway and 4 miles city (part of total 11 miles) and still average 30-33 with gsr w/itr trans
For 1/4 N/A I would go with the B16 transmission since the shaft gearing is shorter. They both have a 4.40 Final Drive ratio.
As mentioned above. The ITR trans is a good alternative since the USDM and 96 Spec JDM versions have the same gear ratio as the B16. 98 Spec JDM ITR will have a 4.78 Final Drive ratio and GSR 4th and 5th Gear ratio.
[/QUOTE]
Thanks man for the good info really helpful! I'll remember your name I'd like to pay and get my Ls trans sent out and built with new gears.
[/QUOTE]
smokerz212
19
05-06-2006 06:10 PM
