1998 honda civic ac expansion valve replacement
Old 05-08-2013, 02:39 AM
Rick1t's Avatar
Default 1998 honda civic ac expansion valve replacement
Greetings
My AC compressor failed last fall....waited until now to replace......as a side note when the compressor failed it started to skweel.....almost like the belt was slipping....and maybe it was...
anyway I will be replacing the compressor and drier.....should I replace the expansion valve as well.....it looks like it would be a pain to change. any thoughts? and how much time does it take to get to it?
Thanks
Rick
Old 05-08-2013, 04:39 AM
nealnanoHX's Avatar
Default Re: 1998 honda civic ac expansion valve replacement
You need to remove the HVAC box under the dash to replace it, not super hard but not super easy. I would just leave the expansion valve be. Most of the time unless you replace it with an OEM Honda valve you will have more problems. For example I replaced mine and now it makes a whistling noise, AC works great but the expansion valve is noisy, not very common. Replace the drier, compressor and condenser and you should be good. Unless your compressor blew up and you have tons of metal in the AC system you dont need to replace it.
Old 05-08-2013, 05:57 AM
Former User's Avatar
If the compressor failed, you also should thoroughly flush the system.
Old 05-09-2013, 02:37 AM
Rick1t's Avatar
thanks for the input.......I was pleasantly surprised...when I call and talked with the local shop I use for things I choose or cannot do....when asked about a vac and fill they said no more than $70........when I said I wanted it flushed they said $10 more......pretty fair I thought...
Old 05-09-2013, 04:49 AM
nealnanoHX's Avatar
Yeah good price. Yes if the compressor came apart internally you NEED to flush the system. A lot of time thought either the clutch fails or the front bearing gets noisy, if this is the case no need to flush but it never hurts.
islandgurl305
07-21-2017 07:07 AM
threeoten
Honda Civic (2001 - 2005)
08-10-2016 08:31 PM
Underlook
07-14-2013 06:05 PM
atauer
Honda Fit
12-06-2011 09:27 PM
erikiksaz1
09-24-2004 07:50 PM
Quick Reply: 1998 honda civic ac expansion valve replacement
