d16y8block/d16y7 head
Old 04-02-2013, 02:50 PM
psychodta's Avatar
Default d16y8block/d16y7 head
is this even possible and the car work properly?
The Grumpiest
grumblemarc's Avatar
Default Re: d16y8block/d16y7 head
Why?
Old 04-02-2013, 02:52 PM
psychodta's Avatar
cause my head on my y8 is messed up and couldn't find a y8 around my area so went and bought a y7 and don't really want to do the full swap if I can just put the y7 head on it and be perfectly running.
Old 04-02-2013, 03:01 PM
psychodta's Avatar
I know it is completely retarded to do this but I need my daily driver up and going so I don't have to miss any more work. if I can swap the d16y8 head with a d16y7 head and be able to drive the car with no issues
Old 04-02-2013, 03:07 PM
Stancetard Hate Monger
eghatch9295's Avatar
yes, same h/g, etc. ground the vtec pressure switch out to trick the ecu into thinking it is there, unless you like check engine lights.
Old 04-02-2013, 03:46 PM
psychodta's Avatar
ok tyvm I don't mind the cel for now I am doing a real engine swap soon just need to be able to drive the car in the mean time
Old 04-02-2013, 04:27 PM
Technical Hero
HondaPartsHero's Avatar
It should be fine you'll just throw an engine light for VTEC solenoid and pressure switch.
dunklehass14
03-27-2016 02:56 PM
pnwjdm
27
02-17-2014 01:31 PM
matt2775
11
01-02-2014 09:08 PM
jaco49
13
11-19-2010 04:23 AM
BLuDoHcReX
11
12-24-2002 09:18 PM
Quick Reply: d16y8block/d16y7 head
