Is a tune needed when switching brands of 1000cc injectors?
Old 03-15-2013, 07:40 PM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
Default Is a tune needed when switching brands of 1000cc injectors?
It came up earlier in a conversation trying to determine if a tune was needed when switching from fic1000cc to precision 1000cc. My opinion was yes you should retune due to different brands of injectors having different flow patterns and causing the fuel to atomize differently.
I was just wondering if I was giving bad info or if I was correct?
Old 03-15-2013, 08:35 PM
moderator emeritus
98vtec's Avatar
Default Re: Is a tune needed when switching brands of 1000cc injectors?
yes. They will have different battery offsets which will throw off the fueling everywhere without setting the appropriate dead times and tweaking the tune.
Old 03-15-2013, 09:04 PM
Thanks Blake. I was thinking at the very least the tune needs to be tweaked as you mentioned.
Old 03-20-2013, 07:18 AM
Fuel Injector Clinic's Avatar
Agreed, I would strongly recommend retuning. But why the switch? If I'm understanding correctly you'd be going from a much newer technology to an older technology?
I'm guessing you're using our 900cc high impedance injectors which flow the same as injectors referred to as 1000s from other companies. (These are ours: http://fuelinjectorclinic.com/d-b-h/IS115-0900H)
MyF20b_Prelude
05-30-2015 08:43 PM
boostedteg4dr
05-05-2009 02:57 PM
andyvaj
04-01-2008 04:59 PM
gamakichi77
10-05-2004 04:07 PM
96redgsr
07-21-2004 09:46 PM
Quick Reply: Is a tune needed when switching brands of 1000cc injectors?
