Removing steering wheel cover
Old 02-17-2013, 09:49 PM
crvinmalawi's Avatar
Default Removing steering wheel cover
Hey folks,
I have a 1996 Honda CR-V and the horn mechanism seems to be stuck or shorting somewhere underneath the steering wheel cover plate. I've had this happen before with a Mazda and with that we simply removed the cover via couple screws, sorted out the short, and replaced the cover. I can't figure out how to remove that cover piece on my CR-V. Seems like it ought to be simple, any ideas? Thanks!
Old 02-17-2013, 10:43 PM
NZ-DB8R's Avatar
Default Re: Removing steering wheel cover
Has a Airbag? Disconnect the battery 30mins before you start working just to be safe.
Will have a cover on the back that you lift up and you will need a torx bit to undo the screws
Old 02-21-2013, 11:39 PM
As far as I can tell there is no airbag, but I disconnected the battery anyway to be sure.
I looked everywhere for a cover and couldn't find anything. I can get the cover to the steering wheel to move up about a quarter of an inch but won't budge after that. Is there some kind of releasing mechanism? I can't imagine this should be that hard. Ideas?
Old 02-22-2013, 11:19 AM
NZ-DB8R's Avatar
Depends if it has an airbag or not. What year is it? Do you have a SRS light on the dash board that comes on when you start the car?
Old 02-26-2013, 09:37 PM
It is a '96 and was imported from Japan to Malawi. I just checked the dash on start-up and there is no SRS light.
Old 02-27-2013, 04:12 AM
dogbiscuit's Avatar
remove these small covers on either side of the steering wheel shown below. once removed you should see two torx screws on either side of the steering wheel cover this is all that hold it in. How about showing us a picture if this still doesn't help
ERIC!
01-02-2009 07:24 PM
Whatislove
Honda Civic (2001 - 2005)
09-22-2008 11:14 AM
Mr.Highlife
14
04-06-2008 10:18 AM
1ntensiveVTECivic
08-07-2003 12:51 AM
LudeyKrus
03-25-2003 04:56 AM
Quick Reply: Removing steering wheel cover
