93 accord H22A p13 cel 22
So the title says it all I got my cel codes and got code 22 wich is my vtec pressure switch but upon looking in the engine everything appears to be fine.. I just bought the car and finaly got it to run not very long ago so I dont know if the wire is set in the right pin on the ecu "any info on this would be fantastic" but this is the pic of the wires running from my vtec into my harness to my ecu.
Re: 93 accord H22A p13 cel 22
for you to get a Cel doesnt mean you have wires bad, maybe your sensor is bad, but in case you have it wired the wrong way you can eassily wired, to Pin D6 and one wire to ground. send me an emai and I will send you a pic of how it has to get done, ones you get it working your car will be a beast ---> joelperez412@gmail.com
