B18B1 HEAD BUILD
Old 12-25-2012, 08:56 AM
jdmb18b1flip's Avatar
Default B18B1 HEAD BUILD
tell me what u think or what i can improve
its a p75 head gonna run stock valves with stage 2 crower springs and retainers with crower 403 all motor cams gonna port match the head to the gaskets so maybe a 1/16 of an inch port maybe lil more a then polish it
them polish the intake many run obd1 injectors and aem fuel rail and regulater
ganna run it on s300 hondata with a tune
just looking for opinion let me know what u think
Old 12-25-2012, 12:07 PM
HOMEMADEPOWER's Avatar
Default Re: B18B1 HEAD BUILD
You might as well upgrade your valves too since you upgrading everything else in the head.
Old 12-25-2012, 03:53 PM
Ok.and.do u think I would-be ok to run different. brands.of. valve springs. pending they have to be grower
Old 12-25-2012, 05:33 PM
spAdam's Avatar
Spring rates are based on the mass of the valve train and the lift, velocity, and accelerations that the valve will see. The last three are determined by the cam design. For that reason, unless you know what you are doing (if you have to ask, you don't!), best bet is to stay with one manufacturer. They have done the work for you.
Old 12-25-2012, 07:51 PM
93ls10.0's Avatar
I would go go b21asomethin intake valves 33mm of love
Old 12-26-2012, 03:06 AM
spAdam's Avatar
You have to open up the combustion chambers to use them or get a p8r head. I recommend the latter.
Old 12-26-2012, 05:54 PM
what kinda power gain do u think I could.make with. the upgrades I posted
and what would.be. better square port.and.port.match the gasket
Posted from Honda-tech.com App for Android
Old 12-26-2012, 06:37 PM
01DC4's Avatar
The 404s work very well!
Old 12-27-2012, 06:34 PM
i have 403 right.now. I might.upgrade later.on or.on a.new.build
Old 12-28-2012, 03:03 AM
Retired Moderator
EsotericImage's Avatar
Personally, If i were going to build a non vtec head, it would be the P8R like Spadam suggested. Larger valves + better flow.. whats not to like?
Old 12-28-2012, 03:28 AM
Can i run my 403 cams in it
Old 12-28-2012, 04:28 AM
Retired Moderator
why couldnt you?
Old 12-28-2012, 04:25 PM
Just cheaking never ran a p8r head
Old 12-28-2012, 04:38 PM
Retired Moderator
do a search and familiarize yourself with it. Flows close to a B16.
Old 01-12-2013, 08:17 AM
ok and the cams i got for my ls will fit in the p8r head and was wondering
for the stage 2 crower cams do i have to run there springs or can i run any type of valve springs as long as there duel valve springs
Old 01-12-2013, 12:15 PM
spAdam's Avatar
jdmb18b1flip
32
12-30-2012 10:09 PM
DagreenEK
Northwest (Sales)
07-01-2007 10:38 AM
b18sihatch
07-12-2006 11:04 AM
1hotintegra
06-09-2003 07:51 AM
Quick Reply: B18B1 HEAD BUILD
