ECU and wire harness help
Old 11-10-2012, 11:50 AM
Hatchbacksonly's Avatar
Default ECU and wire harness help
Im looking to replace my engine wire harness and i was wondering what type of engine harness i should get and if i should replace the ecu with it i have a 90 crx si with a sohc vtec d16y5
Old 11-10-2012, 12:14 PM
civic_b18swap's Avatar
Default Re: ECU and wire harness help
if it was me id get the same harness as you had before, and id keep the ecu unless theres something wrong with it
Old 11-10-2012, 01:52 PM
If i get a new harness will it have the plug that goes into the vtec solenoid
Old 11-10-2012, 03:09 PM
Spug's Avatar
You need the harness that matches the car. Then you modify it to fit the engine, rather than having the harness for the engine and not being able to plug it into the car.
frankiecutz
10-31-2015 03:49 AM
V-SPEC 1
04-23-2014 04:51 PM
2004es2
11-10-2008 07:33 AM
Mikey3000
06-24-2008 04:59 PM
ch00dlz
07-24-2006 09:18 PM
Quick Reply: ECU and wire harness help
