94 Civic clutch Problem
Old 10-20-2012, 03:25 AM
JDMBukLau's Avatar
Default 94 Civic clutch Problem
Hey i have a 1994 honda civic with a stock d series engine. The problem i have it when i change gears if the car is off or driving its hard/heavy to change gears, its not smooth at all, in other words there's alot of resistance. Also im pretty sure that my clutch bearing is broken can this be causing the problem? What can i do to make it shift smoother?
Old 10-20-2012, 05:21 AM
The Grumpiest
grumblemarc's Avatar
Default Re: 94 Civic clutch Problem
How did you come to the conclusion it's a bearing?
Old 10-20-2012, 12:22 PM
JDMBukLau's Avatar
Because it makes a noise from the transmission and if i press the clutch it goes away...
Old 10-20-2012, 12:26 PM
Former User's Avatar
This^ is a transmission main bearing problem.
For difficult shifting, you should also consider that there is air in the hydraulic system, the master and/or slave cylinder is bad, or the clutch pedal is not adjusted properly.
Old 10-20-2012, 12:46 PM
JDMBukLau's Avatar
do you know where I can get a new bearing, and is there anyway to check if the master and slave cyinders are bad, also could it be that i need to change the oil in the tranny?
madvtakkk
01-07-2008 12:46 PM
z2weaver
09-24-2007 02:42 PM
ACottrell
04-20-2005 05:01 PM
Phillip4285
07-14-2004 04:30 PM
GeorgeY
04-18-2003 03:10 PM
Quick Reply: 94 Civic clutch Problem
