Radiator fan switch problem ej6
Old 09-19-2012, 09:34 PM
david420's Avatar
Default Radiator fan switch problem ej6
My rad fan doesnt turn on so i hard wired it. The only problem is the light on the switch i installed is on when the switch is off/fan off. When the fans on the light is off. So im worried it will drain my battery since it stays on when the key is off. Idk how i got it backwards like that.
If someone could point me in the right direction that would be great.
Old 09-19-2012, 09:59 PM
mechanix619's Avatar
Default Re: Radiator fan switch problem ej6
I'd solve the primary problem instead of worrying about the simple fix. Most likely the fuse is blown.
Old 09-19-2012, 10:55 PM
david420's Avatar
i checked the relay with a good one itand it still didnt work. Im thinking it has to be relay or tstat but im just trying to temporarily get it to work before i get a real fix.
Old 09-20-2012, 03:36 AM
Technical Hero
HondaPartsHero's Avatar
Jump the fan switch (thermoswitch) connector with a paper clip with the car running. If the fan comes on replace the switch.
Old 09-20-2012, 04:42 AM
david420's Avatar
ok thx will try that. was almost gonna buy a new one but now i can know for sure.
kirkland08
03-05-2011 01:15 PM
Lloyd Xmas
04-14-2010 09:21 AM
SneezinCD5
02-22-2008 01:40 PM
WeeMan
09-11-2003 05:45 AM
Quick Reply: Radiator fan switch problem ej6
