EK- turbo dreams From Panama!!!
EK- turbo dreams From Panama!!! Update 3/26/2013
Hello HT crew
i think is time to post my project
is a EK 98 LHD black
the first set up when i bought was
B18C1 a 5psi
p28 ebay chip
pistons LS non v-tec
Turbo kit t3/t4 ebay
Fuel pump evo 8
regulator gas OBX
inyectores de 450cc
turbo timer apexi
Auto meter Phantom ( Temp water, oil press, boost)
steering Momo
Rims Volk knock-off's 1 15"
tires 205/50/r15
ebay coilovers / tein springs
front and rear bars
the last update in the last page
B18C1 a 5psi
p28 ebay chip
Fuel pump evo 8
regulator gas OBX
inyectores de 450cc
turbo timer apexi
steering Momo
tires 205/50/r15
front and rear bars
Re: EK- turbo dreams From Panama!!!
the new set up will be...
turbo t3/t4 o gt30 or Silver ghost (wish list)
crankshaft OEM
Piston CP 84mm
Connecting rods
inyecctor de 750cc
Timing Belt Gates
Darton 84mm
Engine Damper (Crank)
Fluidampr-
OEM Oil Pump-
OEM Water Pump-
Timing Tensioner-
Acl Main
ACL Rod
ACL Thrust
hks blowoff
wideband AEM
temp gauge AEM
while am working in the interior
put back on the bumpers so i can check the space for the new intercooler right now am using a evo 8 intercooler.
cleaning the turbo
buy some rims
the best photo of my rims
right now all the interior is gray i will paint to black satin.
you see the difference
more mouldings
i dont like the doors of my car so i will make a new ones.
crankshaft OEM
Piston CP 84mm
Connecting rods
inyecctor de 750cc
Timing Belt Gates
Darton 84mm
Fluidampr-
OEM Oil Pump-
OEM Water Pump-
Timing Tensioner-
Acl Main
ACL Rod
ACL Thrust
hks blowoff
wideband AEM
temp gauge AEM
cleaning the turbo
buy some rims
more mouldings
After cleaning all the interior
painting all the floor
Thanks to the people of Genius, Car central lock, power windows and to raise the glass with the alarm module
nigthmare of cables....
instaling the central lock
installing the power windows
final installation
Thank you for passing by here and see my project, any suggestion to orderBest regards
218 views thanks!!!!!
today i will start with the relocation of the battery, pre audio install.
i will upload photos in the night
Wow, props for making your own door panels!
Why a Darton 84mm sleeved block and only 750cc injectors? What kidn of power are you wanting to make?
am looking 400 -500 whp
the injectors was a give, in this moment i dont know if will be enought for the power that i looking for.
Any advice?
this weekend almost finish my doors set up, include speaker Genius in a new location.
this is the front of my car, you will see the intercooler of Evo8 adapted
this is the idea of the front that i wanna have.
this is the project of this week floor metal mats.
and continue with the new doors cover
my buddy Miguel helping me..
With a resistance of a water heater make a hot wire to make the curve of the top in the door
testing
mi pal checking the fhush
next door
for helping the material have the right angle we use 2 aluminium bars
in the night i will updating more picture, right now looking for decoratives screws to put on the door.
thanks for looking my project
testing
next door
And for last, arrive my seats
right now, putting back all the gauges, radio,wiring, ecu. All the stuff of the dash.
thanks for see my project, any advice will be great.
After some problems with my other car was about to sell the 2 ...
let pass the days to refresh my mind, and thanks to my friends and my mother convinced me to finish the project.
I bought this weekend. Tomorrow finish putting the tablet internal wiring and gauges in place either when the engine is put the plug / play.
I need to do the seat bracket.
And here we go.
Some people said that have the fuel pressure meter inside the cabin is a high risk..
some advice of this.
Thanks
And here we go.
Thanks
Update of my proyect!!!!
Verifying the fit of the bride seats
Cutting my defense so the intercooler have more room to refresh.
Also using the base of some fog lights so i can sue to put a duct to refresh the brakes.
all the delete plates of the firewall
Buy some support to the roll cages and the support rods for the front splitter.
Dremel time!!!, making some support for the gauges.
Here is the new color of my rims!!!!!!
Thanks for view my project.
Sorry for my bad english.
01-14-2008 08:56 AM
