1991 Honda Civic DX - incredible slew of problems
Old 03-28-2012, 02:02 PM
  #26
KINGVEM^^ED6's Avatar
Default Re: 1991 Honda Civic DX - incredible slew of problems
Go to said locations make sure the wiring.isnt coroded,make sure there tight n make sure wiring inst messed up
Old 03-28-2012, 02:24 PM
  #27
octodigitus's Avatar
Oh I didn't see that list in your post. Thanks, although I'd still be clueless as to how to do this. Is there any diagram or anything that would help me out? I found a post on this forum from 2006 with a diagram but the link went nowhere.
Old 03-28-2012, 07:27 PM
  #28
HBK
HBK's Avatar
Interesting thread...
Here are some dumb suggestions to get you to spend more $$$
- Replace the fuse box.
- Check all other fuses and wiring for shorts.
I have had to replace the under dash fuse box before.
Old 03-29-2012, 04:57 AM
  #29
TearSDMF89dx's Avatar
Originally Posted by KINGVEM^^ED6
Check your ground wires
Valve cover to chassis
transmission to chassis
Thermostat housing
gotta agree with vem on this one as my car went through a similar hellish scenario ....checking grounds is easy remove them and clean the cable ends and there mounting points check for broken wires then reinstall... voila ... you're grounded
Old 03-31-2012, 03:39 PM
  #30
ehart13169's Avatar
You can also test the grounds with a volt meter...one lead on the ground wire and the other lead on the metal it is grounded to. If it reads 0 mV, you have a good connection. If it jumps around, or reads 50, 100, or more mV, you do not have a good electrical connection. You can also test it from the ground point back to the negative side of the battery the same way.
Old 04-05-2012, 11:27 PM
  #31
bassfacej's Avatar
The under the hood fuse box goes bad also sometimes causing a random shut down. Usually tapping on it will get it to come back/go out. If so replace it.
Old 06-25-2013, 08:08 PM
  #32
spydercatt1's Avatar
Does anyone know what the root problem ended up being? I'm having the same problem and would like to know if it's as simple as a bad ground before I start throwing parts at it.
tatz9977
05-28-2012 07:47 PM
octodigitus
08-08-2011 09:22 PM
Quick Reply: 1991 Honda Civic DX - incredible slew of problems
