screetching noise at startup
Old 12-18-2003, 01:15 PM
bpetruzzo's Avatar
Default screetching noise at startup
Some times when I start my car, a loud screetching noise happens until I start driving it, at which point it goes away withing in a second or two.
I'm under the impression that it's got something to do with my clutch, but I'm not sure. Nor do I know if it's harmfull. It's starting to occurr more frequently. Any insight?
Old 12-18-2003, 01:17 PM
Do_Ster's Avatar
check your belts
Old 12-18-2003, 02:14 PM
bpetruzzo's Avatar
Default Re: (ntogethernow)
If it were a belt, would it stop once I started driving?
Old 12-18-2003, 02:15 PM
mattssi's Avatar
Sometimes! Depends on how lose they are! I bet it is your alternator belt!
Down Since Day 1
1 point 6's Avatar
Default Re: (bpetruzzo)
It could, where is this noise coming from and any weird feeling coming from it?
Old 12-18-2003, 02:16 PM
Global Moderator
Jimmy's Avatar
Default Re: (1 point 6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 point 6 &raquo;</TD></TR><TR><TD CLASS="quote">It could, where is this noise coming from and any weird feeling coming from it?</TD></TR></TABLE>
Old 12-18-2003, 02:23 PM
SOHC_MShue's Avatar
Default Re: screetching noise at startup (bpetruzzo)
sounds like a belt
Old 12-18-2003, 11:22 PM
bpetruzzo's Avatar
Default Re: screetching noise at startup (SOHC_MShue)
I got out when it started earlier this evening and listened closely. It does sound like a belt, cause it doesn't sound contained (like it might be inside the transmission). But I'm not sure which one it is, cause once I get under the hood it's so loud I've got no idea where it's coming from. But starting out, I've not noticed any trouble. Like the car doesn't run funny or anything.
Any more thoughts?
Old 12-18-2003, 11:26 PM
egturbo's Avatar
Default Re: (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">Sometimes! Depends on how lose they are! I bet it is your alternator belt! </TD></TR></TABLE>
Old 12-19-2003, 04:39 AM
DCStreetHtch's Avatar
Default Re: (egturbo)
pick up some belt dressing from your local parts store. if that doesnt help adjust your alternator belt by moving the alternator. i think we all agree this will be the simple alternator belt fix for you.
-Bryan-
Old 12-19-2003, 04:46 AM
monicle's Avatar
could also be low on power steering fluid because that pump can make some pretty nasty sounds if its running dry, if its not that then id also say belts
Old 12-19-2003, 06:35 AM
SpiritUnreal's Avatar
Default Re: screetching noise at startup (monicle)
It could also be the cold. My car does that as well in the morning, but once the car warms up it goes away.
Old 12-19-2003, 06:38 AM
2000CX's Avatar
Default Re: screetching noise at startup (SpiritUnreal)
alternator belt...just changed mine last night. do your lights dim when the noise is happening? good way to tell if its the alternator belt
Old 12-19-2003, 07:48 AM
blackhatchy's Avatar
Default Re: screetching noise at startup (2000CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000CX &raquo;</TD></TR><TR><TD CLASS="quote">alternator belt...just changed mine last night. do your lights dim when the noise is happening? good way to tell if its the alternator belt </TD></TR></TABLE>
changing mine soon
Old 12-19-2003, 07:49 AM
JimmyAtlantis's Avatar
Default Re: screetching noise at startup (blackhatchy)
Definately the alternator belt...had the same problem.
Old 12-19-2003, 07:51 AM
93egsi's Avatar
Default Re: screetching noise at startup (JRI94)
def. the alternator belt.....check for wear and tear....if there is none....just spray some belt dressing on there and you should be good to go
Old 12-19-2003, 08:25 AM
Multi-paradigm
Good ol' Screwtape's Avatar
Gad demn my dim headlights are a son of a beech!
Old 12-19-2003, 08:31 AM
Down Since Day 1
1 point 6's Avatar
Default Re: screetching noise at startup (R_EG)
You could check the tension on the belts by pushing on them, if one seem tight mess with the tensioner or oil your pulleys.
Old 12-19-2003, 09:02 AM
Default Re: screetching noise at startup (93egsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsi &raquo;</TD></TR><TR><TD CLASS="quote">def. the alternator belt.....check for wear and tear....if there is none....just spray some belt dressing on there and you should be good to go </TD></TR></TABLE>
Don't use belt dressing until you check the tension. If you just throw some belt dressing on and the belt happens to be loose, you're going to throw the belt. If it's just your belt tension don't even worry about the dressing. And if it is the tension, once you get it fixed you will notice a little more power.
Old 12-19-2003, 10:58 AM
The Internet Tough Guy's Avatar
i think i have the same problem. am i on crack or is there not supposed to be a tensioner for this belt? how the hell do i tighten it?
Old 12-19-2003, 11:02 AM
EG-lowrider's Avatar
Default Re: screetching noise at startup (jwn7)
dont use belt dressing period, its just a big messy rip off that seldom works, and when it does, you just have to keep reapplying it about once a week to keep the squeel's away, just tighten, or get a new belt. It's not like its expensive, about 15 bux!
Old 12-19-2003, 11:48 AM
bpetruzzo's Avatar
Default Re: screetching noise at startup (Broke@$$tuner)
If the lights are dimming, they're not dimming enough for me to notice. Although, sometimes, very seldom, when I'm driving, like speeding up the car will let out a tenth of a second of the screetch, and my car kind of sinks. Like it doens't get any power for that split second.
Sometimes my lights dim. When I have my music upp real loud. But I think that's probably unrelated.
Old 12-20-2003, 10:52 AM
b16aturbo's Avatar
Its the alternator. It may have come loose. Had that problem before. And don't use belt looob.
Old 07-30-2011, 02:43 AM
ta2newbie's Avatar
buy the bracket extension for the altenator belt and extend it all the way out
Old 07-30-2011, 03:47 AM
NACvicSi's Avatar
Did you seriously just bump an 8yr old thread just to say something completely unhelpful?
TehGhett0P1mp
08-07-2008 06:13 PM
92integraVTECgsr
05-05-2006 08:15 AM
racingfan
05-02-2005 01:19 AM
coupe99vtec
12
03-01-2005 11:20 AM
VIS250P
01-04-2005 12:49 AM
Quick Reply: screetching noise at startup
