| Welcome to Honda-Tech! | ||
#1 |
Whats up!!! My trans is leaking manual trans fluid out of the drivers side axle seal.. The seal where the intermediate shaft goes into.. I wanta know what trans seals i should get.. i got a 91205-PL3-B02 (40x56x8) for the drivers side.. Is this correct cuz its still leaking and that what honda said to get for a 2000 civic si so i did and its not helping.. The new seal is good and flush with the trans case so you guys know the seal is not messed up or dont ask lol When i look it up i find that the 91205-PL3-A01 (35x56x8) seal is the correct trans seal for the drivers side... Can someone confirm which one is correct, or if im right?? It wouldnt be the first time honda screwed up on me lol
#2 |
Honda-Tech gave me this lousy title
It depends on what intermediate shaft was used, if it was from a '99 - '00 Si/'94 - '01 Integra or Del Sol Vtec then it's the right seal if you used a '90 - '93 Integra Intermediate shaft you need the driver's side axle seal from that car.
"Bacon tendercrisp chicken, the most powerful sandwich in its class." Per ardua ad astra My F/S thread -> http://hondamarketplace.com/showthread.php?t=2900962 |
#3 |
Which seal is the right seal?? i named two seals there... And im using 94 gsr hydro intermediate shaft/94 GSR axles with the 91205-PL3-B02 (40x56x8) seal and its still leaking.. its the 3rd seal i have tried and there all from honda im running out of rides to honda as its like an hour drive each way.. I'm about to just pull and sell my b series.. its very irritating please help! lol Thanks in advance!
#4 |
So you say it depends on what intermediate shaft i use?? well its a 95 gsr i shaft and axles and the seal for that shaft and axles or car is the 91205-PL3-A01 (35x56x8) and "NOT" the 91205-PL3-B02 (40x56x8).. so i been using the wrong seal the whole time.. I'm going to pick up this new 91205-PL3-A01 (35x56x8) seal today and get back to you guys tonight! they have 2 in stock and I'm going to buy them both!!! lol Hopefully it fixes the problem!! Wish me luck!
#5 |
The correct part is 91205-PL3-A01 OIL SEAL (35X56X8) (ARAI) assuming it's a '95 Integra intermediate shaft.
#6 | |
Yes thank you!!! I used that seal, the 91205-PL3-A01 seal like 4 hours ago, i installed it and am back like i said i would be lol.. anyways that seal fixed the problem.. my fault for trusting someone else even from Honda! Thank you for your help! |
| Tags |
| 95, axle, b18b, bell, bellhousing, fluid, gsr, honda, housing, intermediate, jdm, leak, leaking, manual, seal, shaft, trans, transmission |
