B18b/Gsr bell housing/00' SIcase 00' SI Gears Leaking trans fluid..
Whats up!!! My trans is leaking manual trans fluid out of the drivers side axle seal.. The seal where the intermediate shaft goes into.. I wanta know what trans seals i should get.. i got a 91205-PL3-B02 (40x56x8) for the drivers side.. Is this correct cuz its still leaking and that what honda said to get for a 2000 civic si so i did and its not helping.. The new seal is good and flush with the trans case so you guys know the seal is not messed up or dont ask lol When i look it up i find that the 91205-PL3-A01 (35x56x8) seal is the correct trans seal for the drivers side... Can someone confirm which one is correct, or if im right?? It wouldnt be the first time honda screwed up on me lol
Re: B18b/Gsr bell housing/00' SIcase 00' SI Gears Leaking trans fluid..
It depends on what intermediate shaft was used, if it was from a '99 - '00 Si/'94 - '01 Integra or Del Sol Vtec then it's the right seal if you used a '90 - '93 Integra Intermediate shaft you need the driver's side axle seal from that car.
Originally Posted by 94EG8
(Post 45542223)
(Post 45542223)
The correct part is 91205-PL3-A01 OIL SEAL (35X56X8) (ARAI) assuming it's a '95 Integra intermediate shaft.
(Post 45545892)
Yes thank you!!! I used that seal, the 91205-PL3-A01 seal like 4 hours ago, i installed it and am back like i said i would be lol.. anyways that seal fixed the problem.. my fault for trusting someone else even from Honda! Thank you for your help! |
