brake pedal goes too far down before braking
Old 05-20-2011, 04:19 PM
swizz977's Avatar
Default brake pedal goes too far down before braking
how do i fix the brake pedal when i press it it has to go so far down before it actually starts braking its so annoying 92 hatch
Old 05-20-2011, 05:24 PM
Ronnoc74's Avatar
Default Re: brake pedal goes too far down before braking
When was the last time you bled your brakes?
Old 05-20-2011, 05:28 PM
SeanK325's Avatar
probably air or dirt in the lines.
Old 05-21-2011, 04:45 AM
The Grumpiest
grumblemarc's Avatar
Do the pads need changing?
Old 05-21-2011, 08:39 AM
pwebb0207's Avatar
could be air in the lines, fluid leak or fluid bypass.
Old 05-22-2011, 04:42 AM
Carfanatic's Avatar
air, or low brake fluid for sure.
Old 05-22-2011, 09:48 AM
John Galt's Avatar
What happens if you pump the brake pedal? Does it engage earlier?
Old 05-22-2011, 10:53 AM
k20jonny's Avatar
check the brake pads before you do anything. could be as easy as a brake job. other than that i would bleed the brakes
Old 05-22-2011, 05:01 PM
swizz977's Avatar
yea it engages a little earlier why?
Old 05-22-2011, 06:16 PM
95EG2's Avatar
low brake pads does not cause a low brake pedal... possble air in the line(try bleeding first) if not master cylinder going bad
Old 05-22-2011, 06:46 PM
strategy400's Avatar
I would agree, but it always seems like my pedal is higher/firmer after a pad change.
Old 05-22-2011, 07:04 PM
Ek Forever y0!
Libertariat's Avatar
I agree. It could either be the brake pads being nearly gone, or there being air in the lines.
Old 05-22-2011, 07:10 PM
DaOne54's Avatar
the master cylinder adjustes the fluid as the break pads wear.
there is enough brake fluid in the master cylinder for ALL the brake pads to become completely worn(if you're not low on fluid). So the pedal travel shouldn't be affected as the friction material get thinner. (unless they are completely worn down lol)
My bet would be your brake fluid is contaminated.
it should be clear or amber in color.. If its a dark color you should really bleed your brakes.
Brake fluid needs some love too, not just your engine oil.
I was told brake fluid should be changed every 3 years on our hondas.
Old 05-23-2011, 07:44 AM
John Galt's Avatar
Because I had the same problem. I did everything including new pads, fluid change and bleed. Problem still happened. I suspected the brake master cylinder was leaking internally. Honda service said they've never heard of one failing in that manner. Since it was the only thing I really suspected could be the cause, I replaced it. Problem gone.
It may be possible to overhaul the master cylinder, if so that would be cheaper, but since I was able to buy a new one at a fairly good price that's what I decided.
Old 05-23-2011, 08:02 AM
StreetsideStig's Avatar
Originally Posted by DaOne54
Brake fluid needs some love too, not just your engine oil. I was told brake fluid should be changed every 3 years on our hondas.
x2 Check the level and the color.
Old 05-23-2011, 08:19 AM
swizz977's Avatar
i just got a new master but not a new booster im gonna try to bleed everything the pads are brand new
Old 05-23-2011, 11:39 AM
DaOne54's Avatar
I think if the master cylinder was internally bypassing, your brake pedal would sink to the floor once you were completely stopped (like waiting for the light to turn green). Unless its really bad already lol.
Remember when you are bleeding your brakes, (if your doing a 2 man bleed) to put one foot underneath the pedal, so that the pedal doesnt come down all the way down.
or else all the dirt at the bottom of your brake cylinders could be pushed up and cause some damage. You dont want leaking brake cylinders a week later after you bleed your brakes lol
Old 05-24-2011, 02:00 AM
John Galt's Avatar
That's pretty much what was happening, except it would sink nearly to the floor... not all the way. It didn't happen all the time either, just often enough to be scary. A quick pump of the brake pedal, once was enough, brought it back up.
The master cylinder was really old, over 300,000 miles, and yes it's a good idea to change brake fluid once in a while - it had been over five years, maybe ten...
Old 05-24-2011, 04:34 AM
I never even thought about this. Good advice!
Old 05-24-2011, 08:35 AM
Keebler.89civ's Avatar
I agree if you have to pump it and it always sinks and there are no leaks then its the master
mshields4129
06-18-2011 06:18 PM
BrittK
Acura TL, RL & ZDX
12-12-2010 09:03 PM
B18Redline
06-23-2002 09:48 AM
gingboy
07-11-2001 05:01 PM
Quick Reply: brake pedal goes too far down before braking
