D.I.Y Rear wiper delete with plug
Old 03-30-2011, 05:23 PM
DC5/EP3 MOD :)
Type-Spaz's Avatar
Default D.I.Y Rear wiper delete with plug
This DIY is on my DC5 but applies to most all vehicles. This install only took 20-30 minutes of my time but definitely looks great.
Here is my plug, around $25 bucks
And here is how my car sits now
First start with the outside cover over the wiper arm bolt. Just pop the cover up to expose the 12mm nut.
Then pull off the wiper arm
Remove the rubber cover and use a cresent wrench to remove the large nut
Next go inside the car and start with the phillips screw in the handle.
next remove the screws in the tabs that hold up the rear window screen
Next use a door popper to remove the side panels
Then pull down the main wiper motor cover
Here is the exposed hatch
Unplug the motor
Remove the 3 10mm bolts holding the wiper on
Pull it down and shut the hatch.
Now remove the metal washer
and pop out the grommet
Now time to install! put it in the hole and screw it together. That easy!
clean and admire
Old 04-12-2011, 02:32 PM
PittsburghNBP's Avatar
Default Re: D.I.Y Rear wiper delete with plug
Looks so much cleaner. did mine couple months ago.. my plugs different though for a rear wiper delete. looks good though!
Old 04-15-2011, 05:48 AM
Turbo911cm's Avatar
Good stuff.
Did mine a few months back with a different solution, sink hole cover from Home Depot in black.
I'll take a pic tonight
Old 04-19-2011, 08:09 AM
loscar420's Avatar
first off im new to HT so my first post. i never use the rear wiper so this is def a good writ up. quick question: is there a certain plug you use?
Old 04-19-2011, 08:14 AM
BlueIntegraBoy's Avatar
The OP's plug is aftermarket and probably can be found on eBay.
I ended up using the OEM metal plug from a 92-95 Civic hatchback.
Old 04-19-2011, 04:32 PM
yeah the plug i got was around i think 12 bucks off ebay.
http://cgi.ebay.com/ebaymotors/OEM-R...Q5fAccessories
i think this was the one i got.
Old 04-19-2011, 04:53 PM
njn63's Avatar
Originally Posted by Turbo911cm
Good stuff.
I used a white one for the antenna on my Miata.
Old 04-20-2011, 06:58 AM
Push's Avatar
Looks clean Spaz and great to see all your D.I.Y. stuff on here
Old 04-20-2011, 07:33 AM
DC5/EP3 MOD :)
Type-Spaz's Avatar
thank you sir
Old 04-30-2011, 09:43 AM
ChadB's Avatar
just buy the vx - cx civic wiper delete. It will work great..
Dekorum
11
10-15-2008 06:50 PM
egeeb16
10
06-28-2007 01:40 PM
FakeJDMEF8
09-26-2004 07:39 PM
VTECAcuraGSR
09-26-2004 05:29 PM
citanest
10-27-2001 04:51 AM
Quick Reply: D.I.Y Rear wiper delete with plug
