no compression in all cylinders
so my motor took a dump on me a while back and i decided to rebuild my h22a motor with a full overhaul. now that i have it all pieced back together and back in the car. i go to start her up and no start! i then decide i should do a compression test and when doing so i get a zero reading in all the cylinders... before when the motor was out and i had the timing belt on i hand turned the motor with everything at TDC and it all checked out, no hitting noise of any sort.... idk what could have happened. any input would be greatful.
Re: no compression in all cylinders
if it's right before you put the motor in, you're definitely doing something wrong. before the rebuild...you may have to open that thing back up to make sure you put it together right.
either way, i'd get a second opinion from a friend. you may be having a facepalm moment...it happens
so my motor took a dump on me a while back and i decided to rebuild my h22a motor with a full overhaul. now that i have it all pieced back together and back in the car. i go to start her up and no start! i then decide i should do a compression test and when doing so i get a zero reading in all the cylinders... l.
Recheck your top end & timing to make sure your valves are closed when they're supposed to be. Also check both your coolant and oil to make sure your head gasket is functionally seated and not leaking horribly.
Alternatively you could opt for a full leakdown test to find how the air is escaping.
when the engine's out, you hand turn it, you should feel the compression, if not there's something wrong, shouldnt put the engine back in car, much harder to do a timing belt now, but doable, take off the timing belt and match all timing marks, hand turn engine 3 revolution, see if the marks still match, if you already starter crank, there's a chance that a valve hit, that's what happen to a friend's prelude, good luck.
Usually if the valves are bent it doesnt bend all of them in very cylinder.
maybe it just bent a couple.
When you hand crank it do you feel compression building up when the spark plugs are still in?
He should be testing his compression with all of the remaining plugs in, but disconnected from the distributor, so as not to allow **** to fall into the combustion chamber. This will also give you a slight reading even if your head gasket is not sealing between all four cylinders.
it was right after the rebuild before i reinstalled the motor into the car... im going to pull the head off as a last resort thing... tomorrow in the morning im going to set it all at TDC and check all the marks (no biggie)... then im going to readjust all the valves and see where it goes from there... maybe the adjustment might help! and i did install the rings. haha im a noob but not that much of a noob! like i mentioned earlier worst comes to worst i will have to pull head off and see if valves were bent
JDM_EK_JOE
10-22-2007 07:11 PM
