How do I remove the harmonic balancer bolt?
Old 11-25-2010, 08:36 AM
Safebet's Avatar
Icon2 How do I remove the harmonic balancer bolt?
I am attempting to replace the water pump on my granson's F22B2 2.2 L. engine. I am having trouble removing the bolt that hold the harmonic balancer pulley on the end of the crankshaft. It is a left or right hand thread. To undo it, do I attempt to turn counter-clockwise or clockwise?
Please help.
Thanks
Jim
Dina, Texas
Old 12-04-2010, 12:35 PM
Thriftmaster's Avatar
Default Re: HOW TO REMOVE HARMONIC BALANCER BOLT
Good luck, It took me 4 days, 5 different impact guns and a lot of frustration to finally get my sons off. I ended up using a 1000 FT Lbs of tork 1 inch drive impact that I borrowed from a friend whom owns a tire shop that sercices large rigs.
But to answer your question it turns counter clock wise to come off.
Old 12-04-2010, 01:18 PM
Enzo15's Avatar
get the balancer holding tool. I believe it looks like a hex with an open center. this will keep the crank from moving while you try to undo the bolt. the bolt is torqued down to 180 ft lbs
Old 12-04-2010, 01:25 PM
mafia's Avatar
Or get a torch heat up bolt cherry red, then use impact gun.
Old 12-04-2010, 06:32 PM
minilogoguy18's Avatar
1200 ft-lb snap on impact gun, 1 pull of trigger without hammering, that bolt=my bitch.
But if using hand tools, get the holder mentioned, a 1/2" breaker bar and a reeeeealy long 'cheater' pole, oh and a torque wrench capable of tightening it to where it needs to be cause that pulley coming off will ruin your day.
Old 12-05-2010, 11:59 AM
sde780's Avatar
just put on thread lock and tighten it as much as you can when you re-install, no need to torque exactly 180 ft-lbs
I hate this freaking thing my 600 ft lb impact was zipping at my dad's crank bolt for at least 10 min and no dice. Next thing I'm gonna try is heat. I have the crank pulley tool but you need 2 breaker bars and some 1/2" extensions
Old 12-05-2010, 12:04 PM
^Haha, yeah mine did the same but a friend at work came over and was like "use this, it's got 1200 ft-llbs and it zipped it off instantly.
If you have a floor jack you should take the pole off of that to get some leverage, also helps to only use as long of an extension as you need without putting 2 together, you lose torque that way.
romikbal
03-10-2011 05:33 PM
BoltonGSR
11-24-2006 11:00 AM
Johnny Groovez
09-14-2006 10:50 PM
Scooby
06-17-2002 11:40 AM
cool
04-03-2002 04:48 AM
Quick Reply: How do I remove the harmonic balancer bolt?
