grinding noise when i turn left
Old 03-28-2010, 11:19 AM
724chris's Avatar
Default grinding noise when i turn left
it doesnt do it when i turn right. i replaced the axle and all brake parts up front so it isnt them. its not a clicking noise its more of a grinding. anyone have any ideas?
Old 03-28-2010, 12:02 PM
mikeycivic's Avatar
Default Re: grinding noise when i turn left
um need more info
Old 03-28-2010, 01:08 PM
724chris's Avatar
like what?
Old 03-28-2010, 01:09 PM
mikeycivic's Avatar
like when did it start?
Old 03-28-2010, 01:38 PM
724chris's Avatar
I had my driverside balljoint lower break on me while driving.since then
Old 03-28-2010, 01:53 PM
mikeycivic's Avatar
well did you fix the balljoint?
Old 03-28-2010, 02:12 PM
724chris's Avatar
ya or it wouldnt be drivable
Old 03-28-2010, 02:14 PM
Linked's Avatar
how many miles does the tranny have on it? what the condition of the tranny fluid,
may be your differential
Old 03-28-2010, 03:37 PM
724chris's Avatar
would that happen from turning one way? i have a leaky axle and have to add fluid often. could that be a reason?
Old 03-28-2010, 04:04 PM
Ludeon19slol's Avatar
Low fluid level mite be the problem. See if it still grinds rite after u add fluid.
Old 03-28-2010, 04:21 PM
724chris's Avatar
Ill try that out and get back to you
Old 03-28-2010, 06:03 PM
fasterthanueg's Avatar
ive had this problem before and it turned out to be a bad wheel bearing
Old 03-28-2010, 06:09 PM
MrExclusive's Avatar
I had this issue before when turning right after replacing the cv boots, axles etc etc. Check your brake guard. That was the case for me. I just bent it out with a screw driver and the noise went away. Might be the same issue for you probably
edzi
03-16-2018 07:54 PM
cb450scmatt
05-05-2008 02:18 PM
scott1ct
06-11-2007 05:43 PM
tyflip2
12
11-22-2003 07:42 AM
hb_racer
15
03-24-2002 03:21 PM
Quick Reply: grinding noise when i turn left
