#676
1 Post
Ive always loved the stuff you do with your car. Always super clean work. One thing that stands out in my memory is the radiator block off shroud
Said it on FB but I'll say it again garage looks dopee.. actually seems like a decent size the car is in all the way in the pic right?? Updates are awesome I love how the start button came out. I got some dragon plate left over from the crx I got some things in store for the EM1
Oh and I think were having a party here the weekend before christmas if enough people can make it. You guys free?
You still have the S2000?
#677
Let me know the dates I'd like to come chill im sure riley or alec would be down. I haven't seen you guys in awhile. LMK
#678
1 Post
Dam that is long.. and as of now yea. I don't drive much so it won't be bad and the car will have a new suspension this spring. I'm trying to pick up my g mas old camry or maybe put the crx back together and daily that but one winter wont hurt the em1 too bad. what can I do.
Wrd I drove my car the last 2 winters and it held up fine. Ill let you guys know a date asap.
#679
1 Post
So I started working on modding the Buddy Club seat rails so I can run my custom side mounts.
The rails came with 4 mounting brackets for the seat, one on each corner. Since there wasnt a side mount running the length of the rail BC attached the belt mount to the top of the rail.
The first step was to remove the bracket...
Before:
After:
New bracket fabbed up and welded on to allow clearance for the new side mounts:
Before:
After:
#681
#682
1 Post
Thanks bud! I have a Craftsman jack but its a total piece of crap. I suggest something with a dual piston design. Weve got pretty nice jacks at work, I cant recall the brand but Ill take a look tomorrow and let you know. Theyre the best jacks Ive used save for the Brunnhoelzl race jack we use at the track.
#684
Dam that Brunnhoelzl jack is nasty. Just looked it up quite the $$$ though haha. I need to invest in a nice jack I'm tired of pumping for longer then I'm working or driving my car on wood and what not. I dread oil changes lol
#685
just when I thought Id have a free weekend in dec, lever1 said nah bee. Ill be in FL till sunday morning
#687
Honda-Tech Order of Merit
yessir i have the spoon (momo) hub, and the SRS wiring bypass thingie is sitting in the bag... i can't read japanese so the instructions are useless for me
plus, when i put buckets in i'm going to need something to keep the seatbelt light off
PS: you've made me envious, i want to take all of my suspension off and repaint it
#688
1 Post
#690
1 Post
Thanks man! Ive got one for the SRS delete I just did, and had one for the door inserts on EPhatch but it was lost in the crash. Ive been meaning to re-do it.
#692
1 Post
New update boys!
Seat brackets are oficially DONE! Its been a long process but i couldnt be happier with the results. The finished product is really stunning in person. So solid and crafstmanship is the best Ive done so far...
Also, I started work on the male mold for the carbon airbox. As you can see Im using the basic stock shape and mounting points, but im smoothing out all the contours for a streamlined simple appearance.
Started with expanding foam to fill in the big gaps and form the corner in the front.
Trimmed the excess off....
Then layed filler down....
#693
Carbon intake
Is the whole inside filled?
I love the brackets, they really clean up well. Its going to look fire when its on. I noticed that the Recaro brackets have the belt buckle bolt mounted way at the back instead of on the side the Buddy Clubs. That way the female buckle would be able to go through.
That works for you though, the evo buckle is quite cleaner looking.
I was putting in my stock seat back on for the winter since the bucket is a tight fit when I'm all suited up and the damn thing wouldn't line up! 3/4 holes would line up but the last one would not. Im pretty curious as to why it didn't just go in but I ended up putting enough weight on it that I got the bolt in, but it didn't go in straight. I ended up snapping the head of the bolt :thumbsdown: Now I gotta get a new bolt and pull the threaded part out and hope my threads aren't messed up
So you used POR 15 in black? I thought it was only gray?
#694
1 Post
Carbon intake
The inside is all hollow, I just filled the gaps on the outside. This will be a male mold to make the fiberglass female mold that will be used to form the final carbon product.
Sounds like with your stock seat maybe the seat rails werent in the same setting? Like one was in a different position than the other idk thats the only thing I can think of. Tough break though, thats going to be a pita . Once you get the broken bolt out youll def want to re-thread the hole before trying to but a new bolt in.
And yeah I used POR15 to cover the new seat belt bracket then used some satin black to match it the best I could to the rest of the rail. POR comes in gloss black and gloss grey
#695
Hahaha nice. I've been wanting to fab up my intake since the summer but just can't yet. Since the EP3 is hibernating, it should be a good time to get more intensive projects done since you don't have to drive it. Looking forward to more SHG fab!
Yeah I tried playing with the rails being in different positions but it was the left rail not going down all the way. Either the front left or rear left that would bolt. Not both. I spent 2 hrs trying to figure it out but got nowhere.
#696
1 Post
I wonder if maybe one of the tabs on the rails got bent while it was out of the car... did you use it as a seat or anything?
#697
Oh nice. You get the better deal IMO, you car is only going to see a few snow storms probably. Either way it doesn't look like a very snowy season for that matter. Are you guys heading down to FL just for Sebring or more races?
Hrm. Thats probably it you know! lmao, I used the seat in my room for a week until I got my desk/chair in so maybe that was it. That tab is wicked strong but I'll try bending it forward.
#698
1 Post
Yeah def, thats why I offered her the garage first
But yeah Im stoked we havent gotten any snow yet so its going good so far. I dont mind the car staying outside, but when they start salting our complex i dont want the car sitting on salty pavement.
I would def look at the tab, i bet thats what it is!
#699
For sho E, thanks bro. The EG is coming out in full force next year so stay on your A game Its about time I start showing what I can do haha.
