Old 05-08-2013, 08:24 AM
  #2751
PatrickGSR94's Avatar
Default Re: SHG is back! Easy's EP3 goes under the knife...
Originally Posted by MitchConnor
this is a pretty stupid question and I am a noob, but what are the gold cylinders with the braided lines going towards the strut tower?
Remote damper reservoirs. Normal shock/strut dampers have the oil reservoirs self-contained within the damper body itself, where the piston enters the top. Remote reservoirs allow for a larger volume of fluid to be used, which I believe also allows for more damper travel. I'm sure it has something to do with better heat dissipation, too, during track use.
Old 05-08-2013, 08:25 AM
  #2752
SHG_EasyE's Avatar
They're remote reservoirs for the front struts
Old 05-11-2013, 05:37 AM
  #2753
waiting for the perfect fit....
SHG_Chiquita's Avatar
Somehow unsubscribed on iPhone...fixing now
Old 05-11-2013, 12:58 PM
  #2754
SHG_EasyE's Avatar
Hey guys! Finally an update!
Been super busy lately with work but here are a few things new with the car
Got some new parts in, including this SPA Design Dual digital gauge setup for oil pressure and oil temp. It includes a fully customizable display, customizable warning lights, high/low memory and digital outputs for datalogging or external led's etc. It also included both sensors and motorsport wiring harness
Also finally got replacement LED parking lights, as well as some Philips Xtreme power headlamp bulbs
Lastly, Thanks to help from Mike my wheel decal idea was made a reality and I finally got to putting the decals on yesterday. They just what I had hoped... Giving the wheels a little more of a racy look and less of a showy appearance
Much more to come tomorrow!!
Old 05-11-2013, 01:19 PM
  #2755
Loganej8's Avatar
Awesome new aditions. That's the most baller oil gauge I have ever seen!
Old 05-11-2013, 01:23 PM
  #2756
skipunk4's Avatar
Very nice man. Wheel decals came out great. Always lovin the progress
Old 05-11-2013, 02:00 PM
  #2757
Lord of the idiots
[ej]Jonathan's Avatar
damn those wheels are fly
Old 05-13-2013, 03:39 PM
  #2758
-Z Yaaaa_'s Avatar
just my opinion i guess but i dont like the wheels. white, silver, and teal? too many colors on the exterior for me lol.
i always look forward to updates on this. i am subscribed and definitely come back to see what you're up to.
Old 05-13-2013, 04:15 PM
  #2759
splice247's Avatar
Looks very clean. Nice car!
Old 05-13-2013, 04:27 PM
  #2760
DIYKITS@BB4lude's Avatar
I hated the new wheels until you put the decals on. I don't know why, but they look incredible now!
Old 05-14-2013, 07:42 PM
  #2761
SHG_EasyE's Avatar
Thanks for the input guys! The decals really do change the whole look of these wheels on the car
I worked on the car a good bit on saturday, and got started on a short list of long jobs I have lined up for the car over the next few weeks...
I swapped out the upper rear camber link sphericals for new factory bushings, as well as put the bushings back in the rear shocks. Ive still got the inner camber link pivots to replace with original buddy club rubber bushings, and I think Im going to switch to factory rear top hats as well. NO MORE CLUNKS!!
Removed my poly lower knuckle bushings and cleaned them up. The best way to clean off that sticky grease and restore poly bushings is to soak them and wipe down with WD40. Works like a charm! These bushings are a testament to how poly works very well when used in the right application... This is the first time these have been serviced in the 30-35k miles Ive put on them
Then I installed the poly bushings and new factory upper bushing in a new set of powdercoated knuckles donated from the DC5 build (my spherical knuckles will get powdercoated and used in their place)
I also needed extended studs due to the thick lug seats on the Tarmacs, as well as some room for a spacer down the road if I want to experiment. I pulled the rear hubs, masked the bearing openings to keep out debris, and cleaned the rotor mounting surface to bare metal, then resprayed them followed by the new studs.
Suspension going back together...
And with the wheel installed Im really liking the look of the studs peeking out from inside the lugs
Since I had to drive the car home I was only able to get the rear done. This weekend Ill attack the front studs install as well as new front wheel bearings since the hubs have to come apart anyway.
Old 05-14-2013, 07:58 PM
  #2762
SHG_Claudio's Avatar
Man that looks so dope lol. Your suspension is a dream come true I'm sure. I also agree with the studs inside the lugs, looks trick! Loving it.
Old 05-14-2013, 11:21 PM
  #2763
Loganej8's Avatar
Your work blows my mind every time man.
Old 05-15-2013, 06:20 PM
  #2764
00siboy's Avatar
So the decals are custom? Look great.
Old 05-16-2013, 04:31 AM
  #2765
SHG_EasyE's Avatar
Yup
Old 05-16-2013, 02:05 PM
  #2766
00siboy's Avatar
Man, SHG has the hookups...
Old 05-16-2013, 02:55 PM
  #2767
SHG_EasyE's Avatar
We have a vinyl cutter, all our decals and graphics are designed and made in house
Old 05-16-2013, 08:43 PM
  #2768
SlipstreamR15's Avatar
Geez, I just read through this thread...OMG... -_- Your suspension is godly man. I can't wait to get my DC4's suspension to your standard hahaha Can't wait for more updates man!!
Old 05-17-2013, 01:13 AM
  #2769
Gtimportfanatic's Avatar
we'll be doing the fronts tomorrow i assume? lol..
Old 05-17-2013, 08:08 AM
  #2770
SHG_EasyE's Avatar
Thanks man!
Yup! Front studs along with new wheel bearings while I have it apart, rear tow hook install and alignment
Might have my new intake tomorrow tooooo
Old 05-17-2013, 09:10 AM
  #2771
Poly bushings look like that after 35K miles? That's reaaaaly surprising. I had poly shifter bushings on my DC2 for about that long, and the front donut bushing was literally crumbling and turning to dust in my hands, despite that bushing never seeing any kind of rotational or torsional movement. I went back to OEM rubber on those.
Old 05-17-2013, 03:04 PM
  #2772
SHG_EasyE's Avatar
Yup, and if you look back a couple pages you'll see the trailing arm bushing was also in pristine condition. First time it had been apart since install. I've personally never had an issue with poly but I don't deny the problems some people have obviously had.
Old 05-17-2013, 10:30 PM
  #2773
SHG_James's Avatar
Hold up. Booking my flights right now... lol.
Old 05-20-2013, 06:51 PM
  #2774
SHG_EasyE's Avatar
So I spent another Saturday wrenching on the Civic, but this time Dre kept me company as he was doing some work on his SSM as well
I kicked it off with finally installing my SHG circuit tow loop. Ive been waiting since winter 2011 to get one of these things on the car
Stock VS the SHG part
Welded in
Then I masked it off to spray gray around the base
And then the signature orange paint
Then got down on this weekly ritual
Then the main reason I had the car up was to finish the ARP stud install. I pulled the front knuckles apart and stripped the hubs down since they were pretty rusty and lifting the POR I had applied a few years ago.
Here is a hub with a coat of etching primer
Here are the knuckles, Honda wheel bearings, refinished hubs with ARP studs, and new Honda retaining pins for the castle nuts ready to assemble
The scene towards the end of the night ... Two ssm's CHILLEN
Old 05-20-2013, 07:02 PM
  #2775
Yet another flawless batch of work! Love the tow loop and those wheels have grown on me after the emblems.
Quick Reply: SHG is back! Easy's EP3 goes under the knife...
