P0108 CEL Light, can not get it to go away... HELP
I need help with this code.
I have tried everything I can think of. My car is a 98 Integra LS and this is the only code I have. The car misses pretty bad when you first start it after it has set over night. But once the car has been running for a while, I can reset the code and the car will run fine for the most part, it will miss every so often, but the code will not come back until the car cools off and sits for a while. I have changed plugs, wires, rotor, fuel filter, MAP sensor, and I have cleaned my EGR valve. My map sensor wires are not broke, and I have a constant 5V to my signal wire, even when I apply vacuum to the sensor.
Has anyone seen this issue?
Re: P0108 CEL Light, can not get it to go away... HELP
What kind of scan tool are you talking about? Is there anything else I can check without having that tool available to me?
