Help on CEL light
Old Dec 3, 2002 | 07:16 AM
PR_LUDER's Avatar
Default Help on CEL light
I have a 98' lude and made an OBDII to OBDI conversion but didn't use the harness and haven't had any problems since a few days ago. It all started when my car started to hesitate at around 3000 rpm then the CEL light came on. It threw 3 codes code 03, code 12 and code 21. I know the codes but the most rare part is that it works perfectly when the car has just been started but when I drive the car around for a couple of minutes it starts to hesitate at those RPM's. If anything like that has happened to anyone please let me know. The CEL lights now come constantly specially if I hit Vtec. Hope anyone can help.
Old Dec 3, 2002 | 07:44 AM
prelude1897's Avatar
Default Re: Help on CEL light (PR_LUDER)
Code 3: Manifold Absolute Pressure Signal
-High/Low signal
-Open or short in MAP sensor
-Map Sensor
-ECM/ECU
Code 12: EGR Valve Lift Sensor
-Lift Insifficient Detected
-High Voltage
-EGR Valve (with lift sensor)
-EGR Valve lift sensor circuit
-EGR control solenoid valve
-EGR control solenoid valve circuit
-EGR line
-ECM/ECU
Old Dec 3, 2002 | 07:46 AM
Default Re: Help on CEL light (prelude1897)
Are you sure you threw a code 21?? I don't see anything about it
Old Dec 3, 2002 | 08:30 AM
PR_LUDER's Avatar
I'm pretty sure, I think the code 21 is " VTEC Solenoid Valve \\Open or short in VTEC solenoid valve circuit, defective VTEC solenoid valve" . I just don't know what happened because it just came out of nowhere.
Old Dec 3, 2002 | 10:51 AM
Try reseting your ECU by taking off your negative battery wire off for awhile, then reconnect it. If the light comes back on, then you have a problem. The code for the VTEC solenoid is code 22 according to my resources...Go to http://www.hondaprelude.to/main_checkengine.html
nebulabox
Feb 27, 2010 11:08 AM
ThePeanutHatchback
Jun 14, 2008 11:39 PM
K-Spec
Aug 26, 2006 11:04 AM
Prelude_lunatik
Jun 30, 2006 06:34 PM
