Why does my RPM jump up and down?
Old 01-13-2010, 11:36 PM
niwisball3r's Avatar
Icon6 Why does my RPM jump up and down?
Hi. So I recently got my first car and noticed as I'm in neutral going down hill the RPM would jump up and down and seems to stop as I'm braking and stop. What should I do? Oh I forgot to mention I have a 93 Civic HB VX D15Z1.
Thanks.
Old 01-13-2010, 11:56 PM
97ej6dx's Avatar
Default Re: Why does my RPM jump up and down?
it sounds like an IACV issue are there any check engine lights??
Old 01-14-2010, 12:19 AM
iangon's Avatar
yes I had this same problem when at idle on a d16 - it turned out to be the idle air control valve.
Old 01-14-2010, 02:54 AM
No engine check light.
I'm very new to this so will this be an easy quick fix? What do I need to do to fix my IACV?
Thanks for the quick response.
Old 01-14-2010, 05:26 AM
95_Civic_4dr's Avatar
If it is the IACV, you can try cleaning it before replacing. Just follow this guide: https://honda-tech.com/forums/showth...+control+valve
Had to do this for my eg.
Old 01-14-2010, 06:37 AM
VI Boost's Avatar
IACV most likely, and on rare occasions it could also be the TPS but most likely your IACV needs to be cleaned.
Old 01-14-2010, 06:41 AM
Former User's Avatar
Does the CEL work?
Old 01-14-2010, 07:12 AM
JDM_Dream's Avatar
This happened to me too. But it was the speed sensor.
Old 01-14-2010, 08:07 AM
ultraplayer26's Avatar
bingo....
Old 01-14-2010, 11:14 AM
I'll give this a shot today and let you know how it goes. Once I clean the IACV and doesn't seem to do the job, does that mean I need to replace it?
I'm very new to all this, so what is a TPS?
Originally Posted by RonJ@HT
Does the CEL work?
Yea. My wording was a little off to make it sound like the light wasn't working, but would the CEL turn on with my RPM problem?
How'd you know it was your speed sensor?
Old 06-20-2018, 10:35 AM
kxjumper73's Avatar
I am seeing the same exact issue with my wife’s 2014 Honda Odyssey. Were you able to find a fix for this?
Old 06-27-2018, 08:09 AM
SoCalDelSol's Avatar
dam same thing is happening to mine.
Old 06-27-2018, 08:54 AM
Fish Twig
tony_2018's Avatar
Holy ***** to the walls it's happening to my 2025 honda gizmo
frostykue
03-28-2013 08:29 PM
Nisif
11-26-2011 07:22 PM
mxl360
09-07-2008 09:47 PM
verbal_assasin
03-01-2006 01:09 AM
Quick Reply: Why does my RPM jump up and down?
