EJ6 Build, SiR-Turbo
Old 01-04-2010, 07:50 PM
ej6sir-t's Avatar
Default EJ6 Build, SiR-Turbo
Table Of Contents:
Page 1: Intro, Rear wheel house and rust removed, and re finished, Stand alone fuel system build begins in trunk. Old engine with shattered wrist pin pulled. Trunk prepped for paint. All around rust restoration. Removing factory fuel system.
Page 2: Rear Quarter Panel Repair, Garrett and TiAL Parts Arrive - https://honda-tech.com/forums/showth...2705824&page=2
Page 3: Breather Tubing, Turbo Install, Fuel Lines - https://honda-tech.com/forums/showth...2705824&page=2
Page 4: New Integra Type R Cylinder Head Arrives, Rear Component Speaker Install - https://honda-tech.com/forums/showth...2705824&page=4
Page 5: Garrett Intercooler Arrives, Comp Clutch, Modded Fuel Cell - https://honda-tech.com/forums/showth...2705824&page=5
Page 6: More OEM Engine Components arrive for new ERL Sleeved Engine, re-wiring begins for Rywire Harness - https://honda-tech.com/forums/showth...2705824&page=6
Page 7: Bought engine stand, ERL block arrives, Block and Head assembly begin - https://honda-tech.com/forums/showth...2705824&page=7
Page 8: Block Head assembly cont., mapping out my plans for re-wiring - https://honda-tech.com/forums/showth...2705824&page=8
Page 9: ATI Damper arrives, Skunk2 front upper arms arrive, Engine bay prepped for strip and paint, heating cooling ducting pulled for rywire mil-spec connector plate install - https://honda-tech.com/forums/showth...2705824&page=9
Page 10: Working on Battery box, Purchased ASR Sub-Frame swaybar kit, Quaife LSD install, Ducting modified to accept mil-spec connector while keeping heating and cooling ducts, block/trans mated - https://honda-tech.com/forums/showth...705824&page=10
Page 11: Recessed Air box wrap up, Dry Ice Blasting engine bay shaving prepping and primering bay, sub-frame clean up and paint, ASR sub-frame install, battery relocated to trunk - https://honda-tech.com/forums/showth...705824&page=11
Page 12: Re-wrapping chassis harness, painting engine bay, more parts arrive DSS axles, re-coating wheel wells in front, front suspension installation, mil-spec connector installation - https://honda-tech.com/forums/showth...705824&page=12
Page 13: Re-assembling brake lines, everything in engine bay, parts powder coated, block/trans bolted in, EX spec suspension arrives, re-wiring, R888 tires, new EX calipers painted using por15 - https://honda-tech.com/forums/showth...705824&page=13
Page 14: More turbo related parts arrive, R40 Lug Nuts, engine assembly, wiring, tein mono flex pillow ball upper installed, type r front sway bar installed - https://honda-tech.com/forums/showth...705824&page=14
Page 15: More general assembly, wiring power and power distribution up, wiring high power relay for upgraded SPAL fan - https://honda-tech.com/forums/showth...705824&page=15
Page 16: Finishing up rear suspension assembly, clutch pedal with travel stop installed, ground wires and hardware installed - https://honda-tech.com/forums/showth...705824&page=16
Page 17: Re-wiring power distribution with new distribution blocks - https://honda-tech.com/forums/showth...705824&page=17
Page 18: Purchase Tial housing and go-auto top mount manifold, flatten manifold flange , shim locking CHRA rings on turbine housing - https://honda-tech.com/forums/showth...705824&page=18
Page 19: Finish cabin wiring, make wire screen turbo filter, mount FPR, Fuel lines made, Fuel rail/injectors installed, steel and steel hardware coated - https://honda-tech.com/forums/showth...705824&page=19
Page 20: Made vacuum distribution block, choosing push to connect system with info on my type, wiring up signal lines - https://honda-tech.com/forums/showth...705824&page=20
Page 21: Re-Manufacturing Rear brake caliper brackets, interior pieces, start of downpipe, breather lines, R888's mounted & balanced - https://honda-tech.com/forums/showth...705824&page=21
Page 22: Turbo oil return line, breakup with old lady, downpipe finished, turbo coolant feed line, 1st start up VIDEO - https://honda-tech.com/forums/showth...705824&page=22
Page 23: S300 problem wont read factory sensors, Engine wont stay running, diagnosing, trying to contact slowmotion, Hub Centric Ringw Installed, flame guard lower hose, modded headlight... - https://honda-tech.com/forums/showth...705824&page=23
Page 24:
I am starting a build thread, first one ever and im putting it on the forum mid-project and I might jump around a little since Ill be working on different sections of the vehicle concurrently.
First off I feel to a high degree that not only should attention be paid to the restoration, modification...etc of the vehicle but also to the service and maintain the vehicle at the same time to assure the reliabilty that Honda stresses.
Here I am disassembling, cleaning, rebuilding, the windshield wiper linkages with 316 Stainless Steel Hardware and relubricating the necessary areas.
Old 01-05-2010, 07:02 AM
MiG-21 superfan
builthatch's Avatar
Default Re: EJ6 Build, SiR-Turbo
what an odd first post.
subscribed.
Old 01-05-2010, 07:53 AM
iamthefollower's Avatar
can't wait to see what all is being done to this.
Old 08-12-2011, 08:15 PM
ej6sir-t's Avatar
Rust repair
Old 08-12-2011, 08:34 PM
ej6sir-t's Avatar
Cant figure out why it will upload some photos and not others, any help HT?
Old 08-13-2011, 04:04 AM
ej6sir-t's Avatar
Rust bubbling that is now being repaired.
Old 08-13-2011, 04:11 AM
ej6sir-t's Avatar
Another area of deep rust and pitting near the skirt on the drivers rear quarter.
Old 08-13-2011, 08:50 AM
ej6sir-t's Avatar
Here I have cut out both areas of deep pitting. Epoxied in some aluminum strips with 3m auto mix panel bonding adhesive. The strips will help support body filler.
Old 08-13-2011, 09:03 AM
ej6sir-t's Avatar
All the rust has been cut out or ground through completely. I will be adding RCi fuel cell to trunk, thus have removed neck and support which helped me to get at the rust thoroughly. All bare steel will be coated with epoxy primer for guaranteed corrosion protection. I will be adding a brand new (cut from a complete new inner panel) well liner also using more 3m auto mix.
Old 08-13-2011, 09:42 AM
Former User's Avatar
Your pictures seem fine. Can you be more specific?
And glad to see you back again and keeping us updated.
Old 08-13-2011, 11:49 AM
ej6sir-t's Avatar
My photos were too large, I have been reducing size and it has been working fine now.
Thanks.
Old 08-13-2011, 11:54 AM
ej6sir-t's Avatar
The trunk is nearly prepped and the oem tank has been dropped. All existing fuel lines have been removed. The trunk has been sanded down to bare metal in the rusty areas and down to primer in the rest. The trunk will be sprayed with pre clean, then epoxy, and finally paint.
Old 08-13-2011, 12:00 PM
ej6sir-t's Avatar
Here is the patch panel, glued in with some 3m auto mix. As you can also see I have epoxied in a .1 in stainless steel sheet over the fuel filler hole since it will not be used. This way the inner panel will remain completely sealed to the roadway and all its elements for a clean and rust free design.
Old 08-13-2011, 12:03 PM
ej6sir-t's Avatar
Another major area of rust and pitting that was repaired with a dewalt grinder and some evercoat.
Old 08-13-2011, 12:07 PM
ej6sir-t's Avatar
An update on the engine aspects. As of today I had had a b16 turbo, with stock sleeves and built bottom end pusting 360 hp as you can see in my video. I am employing and will continue to employ a Garrett GT3582R. A couple weeks after tuning my wrist pin shattered. The piston held on and I was able to salvage every thing but pistons and wrist pins. I currently have a b18c at ERL performance getting sleeved and bottom end built.
Old 08-13-2011, 06:17 PM
ej6sir-t's Avatar
Here is old b16a with shattered pin. Engine being replaced with b18c ERL Performance sleeved and assembled bottom end with 83mm CP 10:1 manley turbo tuffs, I will be assembling a brand new ITR head onto the motor with all stock ITR components when I get it back from ERL Performance.
Old 08-13-2011, 06:22 PM
ej6sir-t's Avatar
Here is the tiny junk shattered wrist pin. Lesson learned. Always get upgrade pins. Never buy SRP pistons.
Old 08-13-2011, 06:24 PM
ej6sir-t's Avatar
Test fitting fuel system before paint. Here you can see the fuel pump and the post pump filter, both aeromotive.
Old 08-13-2011, 06:30 PM
ej6sir-t's Avatar
Originally I was going to use your basic Earls Performo flex hose for fuel (hose on right). That was untill i read online to test the fuel in the line a couple days. After those couple days smell the hose. If the hose smells like fuel the fuel is seeping through and deterioating the lines. So I had to throw away the performo Flex and move up to Earls speed seal Teflon hose (on left). Teflon line is a much better product, PSI holding, life expectancy, durability, heat tolerance, and correct me if im wrong but has a lifetime warranty.
Old 08-13-2011, 06:38 PM
ej6sir-t's Avatar
Another advantage teflon line has over rubber line is that teflon has a larger inner diameter while also having a smaller outer diameter than its rubber counter part. Teflon is also impervious to any chemicals it will enounter from the elements outside to the additives they put in fuel.
Old 08-13-2011, 06:46 PM
ej6sir-t's Avatar
Here is my RCi fuel cell with some HCLA steel bracketry to securely hold down the 66lbs of fuel that will fill it. It was powder coated satin black.
Old 08-13-2011, 06:49 PM
ej6sir-t's Avatar
Here we are with a simple test fit of the complete system prior to any paint or primer.
Old 08-13-2011, 06:57 PM
ej6sir-t's Avatar
As you can see I have the sump mounted rear ward so as I accelerate the fuel will be forced into the pre pump filter and then into the Aeromotive Tsunami pump. I cannot believe some peoples set ups with stand alone systems. I have seen the sump facing frontwards and the pump frontwards of the sump. I have seen people blatantly not following RCi 's instructions to not secure the cell with the tabs provided, but do so anyways (best example is the kiwi metallic integra featured in Honda Tuning.)
http://www.hondatuningmagazine.com/f.../photo_13.html
link to that integra with improper mounting^^^^
Old 08-13-2011, 07:01 PM
ej6sir-t's Avatar
Bulk head lines ran to front. Bulk head fittings are great for maintaining a sealed pass through of fuel lines, so the elements outside stay out. The fuel system is much more easily serviced this way.
Old 08-13-2011, 07:10 PM
ej6sir-t's Avatar
Here is patch panel (inner well liner) finished glued mainly and welded in very few spots. This is my first time ever with body work and have no formal training so I will be playing the game as it comes.
Let me know what you think of my work HT.
Quick Reply: EJ6 Build, SiR-Turbo
