Crank Pulley Bolt
Old 01-20-2010, 07:28 PM
  #26
The Jar's Avatar
Default Re: Crank Pulley Bolt
Using an impact wrench to tighten stuff is for lousy mechanicians. Idiots are using it even to plastic covers. The wheels are constantly overtighten.
In order to untighten the cranshaft I had to use 4 feet long arm and twist the 1/2" extension bar (20" long) about 90deg. Does it soud like like 180lbs? 550lbs impact wrench could not make it. Of course all plastic cover bolts that were accesible by an impact wrench were overtighten and the plastic broken.
Impact wrench is NOT for precise tightening. Unless you don't care if you ever have to undo it or work for a car shop.
Old 01-20-2010, 08:01 PM
  #27
daltond88's Avatar
my buddy use an impact to tighten my crank bolt on my f22b1 and the next morning when i started it, it came right off. i was pissed. use hand tools and put your car in gear.
Old 01-21-2010, 05:04 AM
  #28
H-T Order of Merit
TouringAccord's Avatar
umm... yeah, that sounds about right. maybe not quite the 90* part but you will twist the extension, especially one that long, a good amount.
Old 01-21-2010, 05:06 AM
  #29
H-T Order of Merit
why not just spend the little extra and buy the special tool? then you dont have to worry about any of that other stuff.
Old 01-21-2010, 05:26 AM
  #30
GhostAccord's Avatar
Originally Posted by willimo
How in the world is anyone going to OVERtorque a 16mm fine thread bolt? Really? Even with professional airtools. That's nuts.
I lol'd at this statement. This cat must be in a profession that requires no specifications of any kind.
You asked, "How in the world is anyone going to OVERtorque a 16mm fine thread bolt?" That is an easy question to answer. Tightening any bolt, no matter what the bolt size or thread pitch, past the applications required specifications would be considered over torqued.
Example in case some people didn't understand.
The procedure for tightening a 16mm crankshaft bolt specifies said bolt to be tq to 180 lbf-ft. Then the mechanic goes and torques it to 190 lbf-ft. Even though nothing may break. Technically the bolt has been torqued over the recommended spec of 180 lbf-ft for this application. Therefore has been over torqued.
Cheers
Old 01-21-2010, 08:50 AM
  #31
daltond88's Avatar
you're right just buy the damn tool its 35 dollars at summit racing
Old 01-23-2010, 08:00 AM
  #32
whltng's Avatar
I am so sorry, but I use professional tools and my MAC torque wrench was just Calibrated by MAC.
I don't know where you get your info from, but I know that air guns are not used in the state of Oklahoma by dealerships, even with torque limiters.
The crank won't turn if you use the proper tool either...
I bet You know all about Honda Engineers too.....
I used to be on a Team in the '90's that ran the 24 hours of Daytona with out any failures, 3 years in a row. No AIR GUNS for any drivetrains.
So who are you?
Oh, excuse me, HONDAGOD!!!
Originally Posted by 92civlude
The pulley bolt broke because it was too loose. Ive seen it more than once. Mostly by novices tightening by the bolt by hand. Its hard to accuratley torque the bolt down because the crankshaft turns while youre tightening it. This is from the mouths of Honda engineers. the best way to insure the bolt wont break is to tighten it with a quality 1/2 gun with adequate air pressure. Real Honda techs do it this way. Anyone that tightens a CS bolt by hand is asking for trouble.
Old 01-23-2010, 08:19 AM
  #33
whltng's Avatar
$3.50 at the Honda Dealer.
Originally Posted by dleccord
how much was the pulley bolt?
Old 01-23-2010, 02:27 PM
  #34
dleccord's Avatar
interesting.
its $25 on ebay?
http://cgi.ebay.com/ebaymotors/94-97...Q5fAccessories
Old 01-23-2010, 04:29 PM
  #35
WTF..... that auction is for a used bolt. would buy that crap for $25.That must be a joke sale.
Part number 90017-PY3-003 94-97 Accord F22 crank bolt $11.95 from Honda parts online. I have no doubts that you can pick one of these up at a dealership for less as whltng has posted.
Old 01-23-2010, 04:41 PM
  #36
nus_dogg's Avatar
^^ Lol. Word.
Old 01-29-2010, 09:55 AM
  #37
EJ2-Fluffy's Avatar
Actually its $69.95 from summitracing.com
http://www.summitracing.com/parts/MO...|1.6L%2f1590cc
But manafacturers do happen to have the other smaller tool which runs around the $30-$40 mark.
http://www.denlorstools.com/home/dt1...ding_tool.html
Old 01-29-2010, 10:25 AM
  #38
dleccord's Avatar
thats a nice moroso tool.
Old 01-29-2010, 10:52 AM
  #39
The Moroso tool would be good for someone who doesn't have a breaker bar. Although it would probably end up being about the same price for someone to buy the small pulley tool and a good quality 1/2" breaker. Honestly, I would rather buy the small tool and a separate breaker bar for $60. At least then you could use the breaker bar for other things.
Old 10-09-2010, 07:43 PM
  #40
natethegreat54's Avatar
what is the thread pitch for a crankshaft pulley bolt on a 94 honda civic??
Old 10-09-2010, 09:28 PM
  #41
redbull-1's Avatar
M14 x 1.25?
See this thread:
https://honda-tech.com/forums/tech-misc-15/common-honda-bolt-thread-pitch-size-dimension-1885652/
Old 10-10-2010, 04:50 AM
  #42
Thanks for the help!! i just need to know so i can run a tap/dye in the crankshaft because the threrad is stripped from over torque i guess
Old 10-11-2010, 07:17 AM
  #43
H-T Order of Merit
if the thread in the crankshaft is stripped, running a tap in there isn't going to help.
goldfinger93030
02-13-2010 06:39 AM
SHG_James
11-25-2008 08:33 AM
puffsef
10-19-2005 09:50 AM
NatedoggAZ
03-18-2004 08:56 AM
95lude-s
03-17-2004 01:25 PM
Quick Reply: Crank Pulley Bolt
