civic coupe wide rim fitment
Old 12-29-2009, 04:54 PM
Milab21's Avatar
Default civic coupe wide rim fitment
I have a 99 civic coupe and before I order up the new lips for my wheels, can anyone with a civic coupe that has ran a 8.5 inch wide rim with stretched tires (195/45R15) had rubbing issues with just a fender roll? Any modifications you had to do to make it fit right and no rub?
I know I have to adjust camber and such I just want to get the body work thing down before I spend money on new lips. I been debating for awhile what size to run. Every time I decide on a size, I want to go wider. Last was 8 inch wide rim all around with 195/45r15 tire but now I want 8.5 all around and if not, just in the rear. Pics would help too! I have searched, all I could find is wheel and tire sizes, no one with what they did for body work. Thanks!
Milab21 is offline
Old 12-29-2009, 05:24 PM
highroller54's Avatar
Default Re: civic coupe wide rim fitment
195's on 8.5 inch wide wheels is such a great idea! I wonder why the tire companys say its dangerous?? They must be stupid!
highroller54 is offline
Old 12-29-2009, 05:29 PM
Milab21's Avatar
I think 195's on a 9.5 wide rim is a greater idea!
If I wanted opinion's on tire size's I would have asked...
Milab21 is offline
Old 12-29-2009, 05:48 PM
Mr. Carbon Fiber's Avatar
You must not read the forum rules on top. Do what you want, its your $$$! But dont cry about it when they lock this thread!
https://honda-tech.com/forums/wheel-tire-56/all-threads-suggesting-tire-stretching-will-deleted-2492509/
Mr. Carbon Fiber is offline
Old 12-29-2009, 05:55 PM
Milab21's Avatar
https://honda-tech.com/forums/showthread.php?t=2492509
I have read them and this isn't about stretching tires, I mean I'm going to but just some input on any size with the size rim I said on fitment would be helpful. And I won't be spending $$ if I don't have a 100 percent mind-set. But thanks though!
Milab21 is offline
Old 12-29-2009, 06:05 PM
It really depends on the wheel. What offset will you be running? Thats very important. 8.5" wide rim is pretty wide. You might not be able to turn real well. Unless you are running different width for the back, I seen people running 9"+ on the back.
Old 12-29-2009, 06:21 PM
H-T Order of Merit
nsxtasy's Avatar
I've seen people have tires blow out with that combination.
On a '99 Civic with 15" wheels, you need either 195/55-15, which can only be safely mounted on rims 5.5-7.0 inches wide, or 205/50-15, which can only be safely mounted on rims 6.0-8.0 inches wide.
195/45-15 is MUCH too small for your car. Unless you're creating a show car for the "low rider" circuit, LOL!
nsxtasy is offline
hillbillycivic
08-15-2012 11:52 AM
elmisias
01-12-2010 04:37 AM
coupeX
06-17-2007 07:51 PM
SoyMilk
03-21-2007 07:32 PM
Sean @ ESG
02-12-2006 01:10 AM
Quick Reply: civic coupe wide rim fitment
