wiper relay
Old 12-18-2009, 04:16 PM
hondarondon9296's Avatar
Default wiper relay
where is the winsheild wiper relay on a 92 accord and is there an intergrated control unit.
Old 12-18-2009, 04:42 PM
redbull-1's Avatar
Default Re: wiper relay
There is an intermittent wiper relay located "under" the underhood relay box. The wire colors are Blu/Wht, Blu/Wht, Grn/Red and Blk.
The Integrated Control Unit is located as part of the underdash fuse/relay box. It is that larger rectangular box somewhat in the middle of it.
Old 12-19-2009, 09:54 AM
so the relay for it isant in the fusebox its underneth it
Old 12-19-2009, 09:55 AM
and would the intergrated control unit have a relay on the side of it. how big is the box. is the box brown
Old 12-19-2009, 10:08 AM
which one do you think would go bad first. i turned my wipers on when they were frozen down and now they dont work. i think i should check the relay first. and how can i test if the box is bad
Old 12-19-2009, 10:40 AM
redbull-1's Avatar
1. Did you check the No. 6 fuse (30A) in the underdash fuse box?
2. If the fuse is okay, the wiper motors may have gotten damaged when you applied power and they were frozen. I would check if there is power at the connector to the wiper motor with a test light or multi-meter. If you get power, then it indicates it may be the motors.
3. It also could be a corroded wire somewhere under the hood, near the intermittent wiper relay. The relay is not in the underhood relay box; but, should be directly under it, near the front left corner.
Old 12-19-2009, 01:01 PM
i check the fuse and its fine. i check the connector and only get 7.3 volts is that normal. shouldnt it be at 12. how can i check if the motors bad.
Old 12-19-2009, 01:02 PM
can you see it without taking the fusebox out
Old 12-19-2009, 01:12 PM
redbull-1's Avatar
You should probably be getting more power at the connector for the wiper motors.
To test the motor, you can apply battery power to the terminals and see if they run. If you can take a picture of the motor connector (wiper motor side) with the terminals and post it, I can mark the terminals to tests.
The intermittent wiper relay should be visible without taking the fuse/relay box out. If you take a picture of the underhood relay box, I can look for it and mark it for you.
Old 12-19-2009, 02:15 PM
redbull-1's Avatar
It may not be your wiper motors, since you said you were only getting 7.3 volts. Start checking the wiring and ground connections. It may be the wiring or can even turn out to the be the switch.
Old 12-19-2009, 06:09 PM
what color wires do i test the motor. and is the control unit inside brown. thanks for all the help
Old 12-19-2009, 06:26 PM
redbull-1's Avatar
To test wiper motor:
1. Disconnect the electrical connector.
2. On the motor side connector:
Low speed: battery positive to the Grn/Blk terminal and negative to Blu terminal.
Hi speed: battery positive to Grn/Blk terminal and negative to Blu/Yel terminal.
3. If motor fails to runs smoothly, it may need to be replaced.
For the integrated control unit, some may be different color; but, it is the larger rectangular unit in the underdash fuse box.
Like I said in my previous post, it may not be the motor, as you said there was only 7.5 volts before the motor.
Old 12-19-2009, 06:47 PM
redbull-1's Avatar
The integrated control unit is #27 in this link:
http://www.hondaautomotiveparts.com/...SE+BOX+-+RELAY
Old 12-23-2009, 05:38 AM
thanks for all the help i am trying to get pictures online should have them today if i dont fix it . and again thanks for all the help
Old 12-23-2009, 11:44 AM
redbull-1's Avatar
No problem, glad to help. Hopefully, you'll be able to pin down what the problem is.
Old 12-23-2009, 05:36 PM
i am not getting any power to the relay. do you think it is the switch or the control unit. i tested the motor and it works
Old 12-24-2009, 06:55 AM
redbull-1's Avatar
1. Does the washer fluid spray? If no or little fluid, check the ground, as it can affect both washer and wiper. The ground should be located hidden behind the washer fluid reservoir.
2. You probably checked the wiring? It may be the switch. I kind of doubt it is the integrated control unit.
Philip Smith
10-20-2021 04:46 PM
sam27
Honda CR-V & Element
03-10-2016 04:24 PM
O2DAB05
07-10-2009 06:11 AM
JOHN WAYNE
07-11-2002 02:23 PM
Quick Reply: wiper relay
