wiper relay
where is the winsheild wiper relay on a 92 accord and is there an intergrated control unit.
Re: wiper relay
There is an intermittent wiper relay located "under" the underhood relay box. The wire colors are Blu/Wht, Blu/Wht, Grn/Red and Blk.
The Integrated Control Unit is located as part of the underdash fuse/relay box. It is that larger rectangular box somewhat in the middle of it. |
Re: wiper relay
so the relay for it isant in the fusebox its underneth it
Re: wiper relay
and would the intergrated control unit have a relay on the side of it. how big is the box. is the box brown
Re: wiper relay
which one do you think would go bad first. i turned my wipers on when they were frozen down and now they dont work. i think i should check the relay first. and how can i test if the box is bad
Re: wiper relay
1. Did you check the No. 6 fuse (30A) in the underdash fuse box?
2. If the fuse is okay, the wiper motors may have gotten damaged when you applied power and they were frozen. I would check if there is power at the connector to the wiper motor with a test light or multi-meter. If you get power, then it indicates it may be the motors. 3. It also could be a corroded wire somewhere under the hood, near the intermittent wiper relay. The relay is not in the underhood relay box; but, should be directly under it, near the front left corner. |
Re: wiper relay
i check the fuse and its fine. i check the connector and only get 7.3 volts is that normal. shouldnt it be at 12. how can i check if the motors bad.
Re: wiper relay
Originally Posted by redbull-1
(Post 40996491)
Re: wiper relay
You should probably be getting more power at the connector for the wiper motors.
To test the motor, you can apply battery power to the terminals and see if they run. If you can take a picture of the motor connector (wiper motor side) with the terminals and post it, I can mark the terminals to tests. The intermittent wiper relay should be visible without taking the fuse/relay box out. If you take a picture of the underhood relay box, I can look for it and mark it for you. |
Re: wiper relay
It may not be your wiper motors, since you said you were only getting 7.3 volts. Start checking the wiring and ground connections. It may be the wiring or can even turn out to the be the switch.
Re: wiper relay
what color wires do i test the motor. and is the control unit inside brown. thanks for all the help
Re: wiper relay
To test wiper motor:
1. Disconnect the electrical connector. 2. On the motor side connector: Low speed: battery positive to the Grn/Blk terminal and negative to Blu terminal. Hi speed: battery positive to Grn/Blk terminal and negative to Blu/Yel terminal. 3. If motor fails to runs smoothly, it may need to be replaced. For the integrated control unit, some may be different color; but, it is the larger rectangular unit in the underdash fuse box. Like I said in my previous post, it may not be the motor, as you said there was only 7.5 volts before the motor. |
Re: wiper relay
The integrated control unit is #27 in this link:
http://www.hondaautomotiveparts.com/...SE+BOX+-+RELAY |
Re: wiper relay
thanks for all the help i am trying to get pictures online should have them today if i dont fix it . and again thanks for all the help
Re: wiper relay
No problem, glad to help. Hopefully, you'll be able to pin down what the problem is.
Re: wiper relay
i am not getting any power to the relay. do you think it is the switch or the control unit. i tested the motor and it works
Re: wiper relay
1. Does the washer fluid spray? If no or little fluid, check the ground, as it can affect both washer and wiper. The ground should be located hidden behind the washer fluid reservoir.
2. You probably checked the wiring? It may be the switch. I kind of doubt it is the integrated control unit. |
