| Welcome to Honda-Tech! | ||
#1 |
Im trying to put a radio from a 1998 Integra into my 01 ITR. I plug it in and the anti-theft light blinks but I get no power when I push the button. I have the code and what not but I think the problem may be with the harness. The harness is kinda hacked up and some wires are capped. Does anyone have a pin-out for the plug that I could use to re-wire the plug?
#2 |
Old Fart
http://www.installdr.com/Harnesses/HA-Wiring.pdf, your 01 ITR may or may not use same plug as the 98 HU, although you did say "I plug it in and the anti-theft light blinks", did you use a plug that came with the HU or one that was still in the 01 ITR,
What color are the wires that are "capped"? 94
You get what you pay for. Nothing is impossible, the impossible takes longer and costs more money. |
#3 |
Hmm. I used the one from the ITR. The ones that are capped are; actually spilts off of some of the regular wires. At some point someone had a system in this car and I think they ran extra wires from certain OEM wires. All of the capped one go into a plug with another wire that comes out of the main harness.
#4 | |
Old Fart
Can you take a pix and post it? I need to know what the wires that are capped and running from a plug are and what wire from the main harness is connected. Could the plug be the stock radio plug still hanging by one of it's leads, [not used by last guy] what color is that one lead. does the plug look like either one of the ones in the link Which plug is it, [plugged into the 01 HU] the first one, [1986-1997/98] or second one, [1997-1998 and newer] in the link I gave you? The problem is that on some Integra the 1986-1997/98 plug/radio harness was used all the way to 2001 and on other Integra the change over was made in 1997/98. As you can see in the link, most of the wiring is the same, [color-designation], be careful with the brown/white, power ant. and right rear speaker neg.(-) are the same color, your 01 HU plug, [if newer type] may have a red lead, your 98 Integra radio harness, [if older type] will not have the red lead, red is illumination ground from "Dash Lights Brightness Controller" neither the illumination power, red/black or ground, [red] are shown on the wire guide in link. 94
| Tags |
| 2001, accord, chrysler, civic, diagram, harness, honda, integra, pin, pinout, plug, plugs, radio, sound, stereo |
