Keyless Entry Stopped Working!
Old 07-31-2009, 03:55 PM
dgerej2's Avatar
Icon3 Keyless Entry Stopped Working!
My car stopped starting in a weird way. When i turned the ignition on, nothing turned on. I recharged the battery and it started. The next day my car died and nothing worked, my starter wouldn't turn over even with a jump. It ended getting towed to a shop. I have a new starter now but my keyless entry doesn't work. They didn't bother fixing it even though I told em'. I thought they were idiots anyway.
My battery is almost 3yo and puts out 12.6 volts.
My windows work
I checked all my fuses
I replaced my remote battery.
I need some advice. Ill be lookin up info in the mean time.
Old 07-31-2009, 04:05 PM
Former User's Avatar
Default Re: Keyless Entry Stopped Working!
Old 07-31-2009, 06:01 PM
dgerej2's Avatar
My car is a 99ej8. I don't have any sort of deck in my center console. I tried anyway. No worky. I wonder if there is a way to program the remote without using the valet button. Thx for the info
Old 07-31-2009, 08:01 PM
Old 07-31-2009, 08:58 PM
jgraham0326's Avatar
in fr more because ever since I bought my EM1 my keyless has not functioned. I have tried reprogramming the keypad and it fails.
Old 07-31-2009, 09:13 PM
More info needed. Do the locks work through the door switches? Any other details? Do you have an aftermarket alarm system?
Old 07-31-2009, 09:20 PM
locks work and all that to my knowledge there is no aftermarket wiring at all.
Old 07-31-2009, 09:25 PM
Is the transmitter battery good? Does the red LED illuminate when the button is pushed? Did you precisely follow the 99-00 transmitter programming instructions?
Old 08-01-2009, 02:28 PM
yes the led works and I followed the steps and the actuators never go off as directed in step 12
Old 08-01-2009, 03:10 PM
Do you have the correct Honda Civic transmitter?
Old 08-01-2009, 04:55 PM
dgerej2's Avatar
1. No luck. My power windows work but the locks don't. I took my car to an eshop and they said it could take about 3 hours worth of work to figure it out($300). They look intimidated too, lol. F that ****. Any advice
2. I noticed that some of the harnesses in the door panel have brown marks on them. I wonder if they're fried. I'll update
3. How do you check for a bad ground?
Old 08-01-2009, 08:56 PM
yes I have the correct transmitter sir
Old 09-30-2009, 08:55 PM
dgerej2's Avatar
I eventually fixed the problem which was: corrosion comming from the positive battery terminal. I replaced both of the cables running from the + terminal. One went to the starter, the other went to the fuse box.
cvanderhoef
04-26-2015 07:45 AM
watacivic
13
06-27-2007 11:28 AM
Setsuna F Seiei
04-09-2007 04:08 PM
puffthomas
05-08-2006 07:01 PM
civic_drvr
01-16-2003 05:09 PM
Quick Reply: Keyless Entry Stopped Working!
