HELP: rear main seal leaking again.........
Old 07-05-2009, 06:38 PM
h22funbags's Avatar
Default HELP: rear main seal leaking again.........
i have an 1997 h22a4 and had a bad clutch slip due to a bad rear main seal any help would be appreciated
first i removed tranny had flywheel resurfaced and replaced rea main seal replaced clutch and put tranny back on an ran grat then 2 days later what do you know its leaking again so we take it back off and the seal is still leaking am i missing somthing? we instaled te seal correctly and the seal retainer isnt leaking but maybe there is a common or known problem any help would be very much apreciated what are the feeler gauge clearances for the seal to crankshaft. thanks
Old 07-05-2009, 07:46 PM
vinuneuro's Avatar
Default Re: HELP: rear main seal leaking again.........
Old 07-05-2009, 08:17 PM
KWayRacing's Avatar
Are you sure it is the rear main again or maybe a tranny input shaft seal?
Old 07-05-2009, 09:13 PM
h22funbags's Avatar
after I took it apart again I used the biggest feeler gauge I had (.027) between the seal and the crank, It went in and all around with no resistance, maybe I just got the wrong seal
Old 07-07-2009, 04:19 PM
KWayRacing's Avatar
ould have rolled the lip who knows OEM seal and you should be good. Good to hear.
Old 07-08-2009, 03:06 AM
bluedlude's Avatar
after a while the rear main seals wear a groove into the crank, if you by chance lined up the lip on the new seal with that groove it will probably leak on ya
Old 07-08-2009, 10:03 AM
h22funbags's Avatar
put a new seal in on mon. so far so good, thanks for the input, i think it was a defect
Old 03-26-2010, 09:13 PM
h22funbags's Avatar
8 months and its leaking again
Old 03-27-2010, 09:20 PM
young_tuner's Avatar
better it was 8 months and not 2 days..
92integracer
11-01-2009 07:16 PM
hondachris1994
20
04-09-2007 06:22 PM
EJ1 wilcox
02-14-2005 10:30 PM
Sephro
07-22-2003 11:47 AM
CivicTuneR95
01-13-2003 10:17 AM
Quick Reply: HELP: rear main seal leaking again.........
