K20A2 - Some CELs and a couple problems
Old 03-31-2009, 05:38 PM
ProMotive's Avatar
Default K20A2 - Some CELs and a couple problems
fixed, thanks
Old 03-31-2009, 09:10 PM
DC5/EP3 MOD :)
Type-Spaz's Avatar
Default Re: K20A2 - Some CELs and a couple problems
I believe our O2 sensors have a fuse. Check for a blown fuse for the o2 sensor.
What did you swap from and what harness are you using?
Old 04-01-2009, 04:34 AM
ProMotive's Avatar
Had a OBD1 B18C1 in it previously, and it's using the Sparkks Racing/K*dupelectroniks harness
Old 04-01-2009, 08:34 AM
DC5/EP3 MOD :)
Type-Spaz's Avatar
god damn that sounds fancy!
Old 04-01-2009, 09:48 AM
ProMotive's Avatar
bump
Old 04-01-2009, 11:51 PM
ProMotive's Avatar
ttt
Old 04-02-2009, 06:37 AM
ProMotive's Avatar
up top
Old 04-13-2009, 10:17 AM
snowboardgeek1's Avatar
I had the P1166 CEL. Its your primary O2 sensor. Check out a helms manual. There are three fuses you need to check for. 2 underneath the dash, one in the engine bay. If those three fuses are good, its your O2 sensor that needs to be replaced. I replaced mine with a bosch o2 primary from autozone. Works fine.
Old 05-07-2009, 12:11 PM
SweetEBPSi's Avatar
I just got this CEL the other day. Do you know where I can download the service manual? Preferably for free.
Old 05-07-2009, 12:14 PM
Razathorn's Avatar
Wow, that's a lot of cam advance!
Old 07-22-2009, 01:40 AM
xhadudkenx's Avatar
Did you ever get the p0341 code fixed? I'm having the same problem with that code right now
Old 07-22-2009, 07:17 PM
hawaiiancb74's Avatar
its a bad 02 sensor, u can get the stock replacements from sparkplugs.com
vrotsos991
Honda Civic (2001 - 2005)
01-23-2017 12:45 PM
all_conference
01-30-2006 02:42 PM
silverboost
08-23-2005 09:11 AM
robbieshonda
10
08-18-2004 08:00 AM
CEC76
02-25-2002 10:20 AM
Quick Reply: K20A2 - Some CELs and a couple problems
