HELP !! -TCC Solenoid Failed
2003 Acura CL type S 161K miles Auto
cel - P0740
causes can be-
-Failed TCC Solenoid (Torque Convertor Control?)
-Poor Electrical Connection
-Low Fluid
When i drive, the car hums. The humming gets louder as the speed increases. It does not get louder with engine speed. Car shifts great and smoothly. When checking fluid, while running, the fluid came shy of the first dot, which i think is very low.
My questions are:
1. do you think fluid will fix this issue?
2. What is the TCC, where is it located, how much does it cost, is it easy to install?
3. are these year CL bad for trans?
Now to rush the gurus, but this is a car i plan to buy and need to give a yes or no by noon. let me knwo your thoughts. Thanks ahead of time
cel - P0740
causes can be-
-Low Fluid
My questions are:
Re: HELP !! -TCC Solenoid Failed
top up the fluid with honda/acura atf, clear dtc's and road test
those CL's did have some problems...I thought they were more related to the 2002 and back models, but I have a few customers that have had to replace the transmission in their 03+ cars as well
time for a new transmission and since you are at 161K miles, chances are you are not going to get help from acura on this one.........
what color is the fluid?
i already called the person and said ill pass on buying the car
Where can I find a diagram (picture/manual/etc.) of the location of the TCC Solenoid (transmission that shows its location) on a 2001 Honda Accord LX 4 cylinder?
teknohatchie91
22
09-18-2016 11:42 AM
cometflyer
Honda Civic (2001 - 2005)
11-25-2015 08:32 PM
PHXHonda
Acura TL, RL & ZDX
07-09-2012 02:58 PM
