b-series eating up starters
Old Sep 19, 2011 | 08:48 AM
98integralsB18's Avatar
Default b-series eating up starters
Alright, so my buddy has a fully built b20 stroked high comp and some other modifications. Here is what happens starter starts to go, we put a new one in its good for like a month the progressively gets worse, one day might start 10/10 then 8/10 then 4/10 etc. I was wondering what would cause it to eat through starters we are on number 3 could it be a wiring issue or something with the starter and flywheel? thank you
Old Sep 19, 2011 | 12:25 PM
frankenghia's Avatar
Default Re: b-series eating up starters
if you have high compression you may need a high torque starter. A factory starter will get eaten up fast if your motor has high compression. Its alot of stress and strain for it to turn your motor over.
Old Sep 19, 2011 | 03:11 PM
okay, any other possibilities that could cause or solve this?
Old Sep 19, 2011 | 04:25 PM
If your eating up starters but don't have a short or the incorrect voltage at the starter, then this is most likely your problem. Any engine I have built with high compression has needed a high torque starter. Did you guys do the swap? If so, did it start fine before? Check the voltage at the starter? Voltage while cranking?
Old Sep 19, 2011 | 04:48 PM
94dxeh2's Avatar
It has gotten to the point where the starter no longer cranks. The previous owner did a number on the wires in the dash so there is a possibility of a short, however the car has seemed to go through the previous two starters in the same fashion. I'll have to check the voltage readings tomorrow at work. I am reluctant to go out and buy a high torque starter until I am sure I diagnosed the problem correctly. Also as a reminder to 98integra: na all the way.
Old Sep 19, 2011 | 05:54 PM
haha yeah yeah boost>na all day. We will figure it out bud!
B18C_EJ8
Jul 10, 2011 10:26 AM
The_Head
Nov 7, 2005 04:55 AM
cervasa
10
Dec 28, 2004 05:45 PM
