equal lenght axle D series
Re: equal lenght axle D series
I don't think so.
the only hondas i've seen that have the same axles, had an intermediate shaft between the trans and driver side axle. You could maybe do it with some custom work.
Seagull Management
It does
It did The transmission, axles and intermediate shaft aren't exactly common though, most guys use anything but the ZC tranny so they can get axles, some also use the ZC tranny with an Si final drive, again so they can use normal D-series axles.
They do, or at least thats what I'm told
PHANTOM MENACE
Originally Posted by 94EG8
...some also use the ZC tranny with an Si final drive, again so they can use normal D-series axles.
And to take things a bit further, if you really wanted to do this "conversion" you'd need the DOHC ZC specific axles (or equivalent but that'll lead into another debate/discussion about what REALLY works), the intermediate shaft, and the differential from the DOHC ZC specific transmission. If I'm not mistaken, the mounting point is already cast into the block for the intermediate shaft to be mounted but won't be threaded.
PHANTOM MENACE
Here, just so you can visually see. This is a D16Z6 block. You can see the three mounting holes here right underneath the oil filter. They are there but with no threads.
And here is a DOHC ZC intermediate shaft mocked up. The only thing that I encountered is that the block needs to be notched a bit to clear the curved part of the bracket that is facing the block.
24TEN, do have pictures of the half shalf and the driver axle separated. I wanna know which one is male and/or female.
You are a great help. So from what I understand the half shalf only fit the zc diff.
I was going though some picture on my hard drive. And from the look of it the Civic 92-95 rtsi(awd) have equal lenght axle too.
PHANTOM MENACE
Here's another thread that might have some useful information:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/dohc-zc-si-trans-wo-intermediate-shaft-2364057/
If you need any measurements, I can help you there too. I have a pair of normal D series axles and a ZC tranny as well as two Si transmissions, one cable and one hydro. All these parts are out of the car as I am replacing and dismantling a bunch of stuff.
