Convert a 7 wire O2 sensor to a 4 wire?
I've searched and searched and this is all I found.
http://www.hybridautomotive.com/tech/o2/
Can anyone confirm that this will work and
get rid of the check engine light?
The sensor was broken off during a head swap.
The new 7 wire is $400.00
The 4 wire universal is $50.00
A no brainer lol
Modified by randyqnt at 5:53 AM 10/16/2008
A no brainer lol
Seagull Management
Re: (randyqnt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by randyqnt »</TD></TR><TR><TD CLASS="quote">bump.. will it work?</TD></TR></TABLE>
If you're still running the stock D16Y5 (HX engine) then I doubt it. VX/HX civic use a very expensive primary O2 sensor and there really isn't any way to get around it. The info you posted is converting the harness to run a 4 wire O4 sensor when swapping in an engine that uses a 4 wire O2 sensor.
Re: (94EG8)
search for a NGK L2H2, it's the sensor that you need, it can be found for a fraction of what honda wants for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 »</TD></TR><TR><TD CLASS="quote">The info you posted is converting the harness to run a 4 wire O4 sensor when swapping in an engine that uses an ECU that requires a 4 wire O2 sensor.</TD></TR></TABLE>
fixed (the engine doesn't care, the ECU does)
zx2gotboost
02-16-2006 02:19 PM
DaveFazari
10-11-2005 01:12 PM
02, 7wire, 97, civic, converstion, convert, converting, convertion, honda, hx, o2, sensor, swapping, vx, wire
