transmission; how many quarts for your civic?
Old 06-17-2008, 07:48 PM
G2_Fella's Avatar
Default transmission; how many quarts for your civic?
last time i flushed out my tranny fluid it used up 2 1/2 quarts. now only 1 quart, and it started spilling out like a mug. i still force a second quart in there. but i think i've only used up 1.5.
what you guys think?
Old 06-17-2008, 08:52 PM
vtecb18c's Avatar
Default Re: transmission; how many quarts for your civic? (G2_Fella)
what kind of trans? my b16 trans takes a little less than 2 1/2
Old 06-17-2008, 08:54 PM
Davus's Avatar
At dealership 3 days ago, I was informed my D16Y8 automatic transmission takes 2.7 quarts. What transmission are you on?
Old 06-17-2008, 09:48 PM
G2_Fella's Avatar
maunual. d15b
Old 06-17-2008, 11:12 PM
luvmihatch's Avatar
Default Re: (G2_Fella)
just drain it all out then fill it up till ti starts coming out of the fill hole... thats what i do.. if its wrong then hasnt broken yet.. just use honda mtf ftmfw.
Old 06-17-2008, 11:29 PM
HT White Ops
BlackDeuceCoupe's Avatar
I drain my tranny with the car on jacks, and fill my tranny with the car sitting on the ground.
In my experience, D-series manuals take a little less than 2 qts. and B-series manuals take a little more than 2 qts.
I don't know anything that takes "only 1 quart"...
Old 06-18-2008, 03:19 AM
96 EX's Avatar
Default Re: transmission; how many quarts for your civic? (BlackDeuceCoupe)
As the man above me said, I also did it on jack stands and then filled it up on the ground. Ive got a d16y8 an I think it took about 2 quarts and if I could have added anything probably would have been minimal.
P.S. Dont forget the crush washer either! Only .32 cents!
Old 06-18-2008, 05:38 AM
sorrule's Avatar
how do you guys get two quarts in there using the fill hole? I never could do it, now I go through the VSS hole.
Old 06-18-2008, 10:31 AM
HT White Ops
Default Re: (sorrule)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sorrule &raquo;</TD></TR><TR><TD CLASS="quote">how do you guys get two quarts in there using the fill hole? I never could do it, now I go through the VSS hole. </TD></TR></TABLE>
You gotta use a funnel for an automatic transmission such as:
They only cost a couple of bucks...
Stick it in the tranny fill hole below you lower the car. Snake it down between the intake tube and the firewall.
Fill your tranny, pull the funnel and cap it off!
Simple pimple!!!
JdmBoii253
11
07-21-2013 12:24 PM
JDMlyfestyle
11-01-2005 03:59 PM
91sleeper
11
06-21-2004 08:48 AM
92HB_HB
10-21-2003 12:29 PM
Malgerus
07-10-2003 02:03 PM
Quick Reply: transmission; how many quarts for your civic?
