corrosion inside my distributor
Old 09-09-2007, 05:20 PM
Ruben19's Avatar
Default corrosion inside my distributor
i had this problem since i bought the car. Corrosion build up on the 4 terminal inside the cap. this make my car misfire and lose power. Couple of years later i bought a msd kit, that include the box,coil and cap. same problem. i bought different caps and rotor but still the same ****.
im thinking about getting rid of the msd system and buy a new distributor. I have to clean the corrosion every week so the car can run in better conditions.
let me know what you think
Is a 2000 si
Old 09-10-2007, 10:38 AM
Ruben19's Avatar
come on guys.
i know someone had this problem before.
Old 09-10-2007, 10:48 AM
Kegan's Avatar
Make sure you use the seal that comes with the cap. That could be a cause.
EG2Driver's Avatar
Default Re: (Ruben19)
mine used to misfire every so often because the seal to the distributor cap was too thin, even though it came from Honda. I used some dielectric grease on the seal and haven't had any problems with it. I stored the car outside last winter for 5 months and it started right up after that time.
Try that and then see if that works.
Old 09-10-2007, 10:53 AM
carloselpavo's Avatar
Default Re: corrosion inside my distributor (Ruben19)
What cap & rotor are you running now? the problem might be on the conbination
Old 09-10-2007, 12:03 PM
Ruben19's Avatar
msd cap and rotor.
new seal and i always use dielectric gease.
im buying a new distributor.
Old 09-10-2007, 01:12 PM
My car was doing the same until I use a msd cap with a rotor that wasn't copper. 4 months with that set up and no problems.
Old 09-10-2007, 10:34 PM
Ruben19's Avatar
i used none copper rotor before.
same result
Old 09-11-2007, 06:50 AM
Default Re: (carloselpavo)
well you said you were using msd cap & rotor. MSD parts are copper. if so, keep the cap and change the rotor for a steel looking one.
Old 09-11-2007, 10:22 AM
Ruben19's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carloselpavo &raquo;</TD></TR><TR><TD CLASS="quote">well you said you were using msd cap & rotor. MSD parts are copper. if so, keep the cap and change the rotor for a steel looking one.</TD></TR></TABLE>did that already but same ****.
AndyD
12-22-2014 03:13 PM
ludecrasy87
04-27-2007 09:41 AM
br1ev8
12-11-2005 09:25 AM
TJSUPE
06-26-2004 11:48 AM
2camsaam
10-03-2002 12:34 PM
Quick Reply: corrosion inside my distributor
