Replacing 98 Civic power window regulator?
Old 08-09-2007, 10:08 AM
loki2323's Avatar
Default Replacing 98 Civic power window regulator?
The car already has power windows but the drivers side motor is starting to go. Is this just a simple swap type of install? I'm assuming I'd just remove any bolts/screws and slap a new one in place of the old one?
Old 08-09-2007, 10:15 AM
99fbpem1's Avatar
Default Re: Replacing 98 Civic power window regulator? (loki2323)
have you bought a new one, how much was it?
Old 08-09-2007, 10:25 AM
Global Moderator
tech8's Avatar
Coupe (2 door) or Sedan (4 door)?
Old 08-09-2007, 12:03 PM
loki2323's Avatar
Default Re: Replacing 98 Civic power window regulator? (tech8)
It's a coupe.
I haven't looked much, but they have some on fleabay for about $60 shipped
Old 08-09-2007, 12:10 PM
Global Moderator
tech8's Avatar
Here is a Technical Service Bulletin (TSB) which shows how the window regulator is.
http://www.tegger.com/hondafaq...e.pdf
You should check that the power window switch is okay before you replace the window regulator. Also, try cleaning the rubber channels with q-tips and rubber alcohol, and then apply silicone grease or spray to the rubber channels; this may help the windows go up and down easier.
Mike's Honda
12-17-2017 03:50 PM
gqskrub
04-19-2016 06:43 PM
98civ98
02-04-2014 02:40 PM
rjb8806
03-17-2013 08:06 AM
Quick Reply: Replacing 98 Civic power window regulator?
