ap1 vs ap2
ap1 vs ap2
i am going to get a s2k soon so i need to know the difference is...any information is greatly appreciated...i want to know which one is worth buying...thanx
No it didn't.
It gave me 4.
Anyways...I was just asking the dealership the same thing.
Minor under-body layouts (I believe exhaust goes under//over something differently) as well as front end and rear end.
2.0 vs 2.2!!
It gave me 4.
2.0 vs 2.2!!
Re: (james_ls)
https://honda-tech.com/zerothread?id=1283232
https://honda-tech.com/zerothread?id=1342107
https://honda-tech.com/zerothread?id=1751975
https://honda-tech.com/zerothread?id=1777766
https://honda-tech.com/zerothread?id=1477031
https://honda-tech.com/zerothread?id=1217072
https://honda-tech.com/zerothread?id=1145356
https://honda-tech.com/zerothread?id=1121330
https://honda-tech.com/zerothread?id=1046873
https://honda-tech.com/zerothread?id=725192
https://honda-tech.com/zerothread?id=679343
is this enough?
is this enough?
Re: (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s »</TD></TR><TR><TD CLASS="quote">IBFTL
btw...
AP1 OWNZ </TD></TR></TABLE>
The right combo of ap1 and ap2 parts owns Like some custom rod/stroke ratios usin an ap2 block with an ap1 crank. 11k rpms anyone ? I wish i had unlimited $$. Lol
btw...
Re: (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s »</TD></TR><TR><TD CLASS="quote">Who needs 11k rpm? I can get the joob done with less....... But ill take a k24 crank! </TD></TR></TABLE>
Re: (18psi sohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 18psi sohc »</TD></TR><TR><TD CLASS="quote">The right combo of ap1 and ap2 parts owns Like some custom rod/stroke ratios usin an ap2 block with an ap1 crank. 11k rpms anyone ? I wish i had unlimited $$. Lol</TD></TR></TABLE>
wish i had unlimited money too
Munkyw3rkz.webs.com
1 Post
Re: (18psi sohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 18psi sohc »</TD></TR><TR><TD CLASS="quote">there is a replacement for displacement.. RPM .. </TD></TR></TABLE>
NEGETIVE!
NEGETIVE!
Re: (S@nt0s)
no ? lets do some math..
an f24c would flow about 5,430 cfms at 8grand,
an f20c would flow about 6,100 cfms at 10.5grand.
It's top end hp but with the right cams and gears the power band could be just as usable. People already rev there f22c to 9 grand and i've seen ppl rev the f20 to 10. So if you were to take an f22c block and put an f20 crank in it with custom longer rods the rod/stroke ratio would be good for probably at least 11k rpms. Finding the cam to make use of all that rpm would be a mission tho..
Munkyw3rkz.webs.com
1 Post
Re: (18psi sohc)
honestly, who the hell needs all that rpm other then F1 guys? no one here i would say 9K is more then enough for "US" street/road/drag guys.
i see your point totally, but let be real here displacment gets the job done. torque is what moves the masses....
Re: (S@nt0s)
It sounds like a great idea but also has the drawback of increased cylinder wear.. I don't kno if the H22 pistons would be a good idea tho. This guy built one who posted on s2ki and said that the valve reliefs on the H pistons look like they'd need work. http://www.s2ki.com/forums/ind...49168 . He used custom frm pistons and rods.
Custom rods would be the only way to go if I was to build a high rpm engine.. I think that's the only way to go if you build the stroker too tho.
Munkyw3rkz.webs.com
1 Post
Re: (18psi sohc)
with custom cams you will have to do a lot of R&D yourself with specs since their isnt much out there for the F20/22's. or just sit back and see what works out later down the road.
Bisimoto engineering will be in development for F20/22 engine parts for the pwer freak in mind, But it will be sometime before this is done.
