hours of labor for clutch master cylinder replacement
Hi,
I need to replace my clutch master cylinder. I generally have the Honda dealer do all services, since they have a reasonable labor rate ($80). When I called in, they told me that it would take 4 hours of labor to replace it. I made sure that they were talking about the master cylinder and not the clutch/trans. They told me it would be 4 hours for a total of $320 before taxes.
Does this sound reasonable? I searched and it seems that some people can do it in about 30 minutes (if they did it before).
Any help would be appreciated. Thank you.
-Brian.
-Brian.
Re: hours of labor for clutch master cylinder replacement (MoogieBoogie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MoogieBoogie »</TD></TR><TR><TD CLASS="quote"> it seems that some people can do it in about 30 minutes (if they did it before)</TD></TR></TABLE> even if you have never done it before it should take less than 1 hour.
sounds like the dealership is going nuts on you.
Re: hours of labor for clutch master cylinder replacement (Relic1)
reminds me of them changing brake pads, padas=$50 labor=$300 you should change it yourself, and remember to bleed the system.
Unceasing Measure
It's two nuts on the firewall - easy to get to with a 12mm ratcheting wrench - and a stud /cotter pin connection at the pedal. You can do it
EDIT: you should look up "bench bleeding" before you slap the new one in there
Ek Forever y0!
Re: hours of labor for clutch master cylinder replacement (Archidictus)
There's a reason I call it the STEALERSHIP.
It's not bad, I'm a "work-on-my-car-phobe"
So once I got over that the fix was easy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MoogieBoogie »</TD></TR><TR><TD CLASS="quote">Hi,
-Brian.</TD></TR></TABLE>
holy crap, $320 just for a clutch master cylinder? I changed mine for about $40 and like 30 min of my time.
Thanks guys.
I guess I'll try to do it myself. The thing is, the dealer often gives fair prices - their timing belt change, parts and labor, is $209.00 plus tax. I'm thinking that there may be a misunderstanding, but I don't want to take a chance. I'll try to fix it this weekend.
Re: (MoogieBoogie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MoogieBoogie »</TD></TR><TR><TD CLASS="quote">Thanks guys.
I guess I'll try to do it myself. The thing is, the dealer often gives fair prices - their timing belt change, parts and labor, is $209.00 plus tax. I'm thinking that there may be a misunderstanding, but I don't want to take a chance. I'll try to fix it this weekend.</TD></TR></TABLE>
Maybe they misheard you and thought you said the clutch? I had mine done at a shop once and it didnt cost me anywhere near that. For sure you could do it yourself. Pick up a helms manual that can walk you through it.
Re: (ek forever guy)
is it the same for all hondas, replacing the master cylinder?
Speaking of hte stealership, i took my 99 si, to get a new clutch put in. They wanted 400 for parts, and 600 for labor? i was like wtf 1grand for a clutch install, i just left.
#1 Super Guy
Re: (mark_is_gay)
Yes the procedure is the same. The clutch master cylinder is easier to replace than it is to bleed. The bleed takes the most time because each pump of the pedal only moves a little bit of fluid. It takes forever for the air to make it from the master cylinder to the bleed port on the slave cylinder. And god help you if you let the reservoir go dry...
I'm sure bench bleeding the CMC before connecting the hard line would make the process that much easier (though I don't do it)...
It's seriously a simple process, but I believe the dealerships labor estimation. I left my Element at the big "H" to get a CMC replaced under warranty and it took those retards 3 days to get the job done (and it blew out within a month).
I am getting charged 398$ today ... then i looked up parts and there is even a video online for this ... 30 min to 1 hour job!! parts 25-75$ depends on what brand you buy..
ZenDynasty
24
06-01-2008 07:56 PM
