How to tell if my amp is blown.
Old 05-27-2006, 03:16 PM
TeenyTymer69er's Avatar
Default How to tell if my amp is blown.
Hey everyone I need to know if my amp is blown or if something else is wrong. I have a Directed Audio 750d amplifier, pushing 2 12" Powerbass Evolution series subs. The amp will go on in the green power light but then 2 seconds later turn into the red protection mode light. I checked my ground, fuze in fuze holder, amp fuzes, power wire, and everything else. The amp is about a little over 1 year old. I'm stomped and need some help.
Old 05-27-2006, 03:28 PM
They let me pick
mrdeadman's Avatar
Default Re: How to tell if my amp is blown. (TeenyTymer69er)
if you take it to some car audio place, they can check it for you. i don't know any other way. ill go look around for a bit.
Old 05-27-2006, 03:29 PM
They let me pick
mrdeadman's Avatar
ok, i found this link: https://honda-tech.com/zerothread?id=267469
im still looking for more because i would like to know too.
Old 05-27-2006, 03:40 PM
02 accord's Avatar
Disconnect the subs from the amp, and turn it on again. If the light stays green, you have a short in the speaker wires or sub(s). If it does the same thing, then you have an internal amp problem.
Old 05-27-2006, 03:54 PM
Default Re: How to tell if my amp is blown. (02 accord)
Alright let me go do that now.
Old 05-28-2006, 05:58 AM
O.G. triple O.G.
NVturbo's Avatar
After all this time, I still dont' understand how anyone can BLOW up an amp. I have installed several types (Rockford Fosgate, Orion, LINEAR POWER, HiFonics, Alpine, etc...) and NONE has ever blown. CARELESSNESS and insufficient knowledge of car audio is what destroys amps...I GUESS.
Old 05-28-2006, 06:04 AM
Default Re: How to tell if my amp is blown. (NVturbo)
I dont think it would be carelessness because it was installed for me at a high end car audio store. My amp boost controller is always less then half way up and on my headunit always at -4. I usually turn the volume up to 20 and one day I guess it just took a **** on me as it just cut off while I was driving.
Old 05-28-2006, 06:16 AM
O.G. triple O.G.
NVturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeenyTymer69er &raquo;</TD></TR><TR><TD CLASS="quote">I dont think it would be carelessness because it was installed for me at a high end car audio store. My amp boost controller is always less then half way up and on my headunit always at -4. I usually turn the volume up to 20 and one day I guess it just took a **** on me as it just cut off while I was driving.</TD></TR></TABLE>....."Professional" installers do f*ck up too. Just because they work there..that doesn't mean they don't. Good example...My older brother took his 97 Camry to this big chain car audio shop to have his system installed. The dumbasses drilled into his gas tank to "bolt up" a ground. How stupid is that?!! I'm sure there are plenty of bolts back there they could have used for ground.
FREEMAN'S CAR STEREO
Old 05-28-2006, 06:20 AM
Yeah I do know what your saying but, I couldnt pass up the offer on the free install. My family knows them for a few years personally and there good guys. They also chose my set up. I dont buy shitty stuff for my car so I dont think its the quality of the stuff that was chosen for me.
Old 05-28-2006, 07:11 AM
O.G. triple O.G.
NVturbo's Avatar
that's cool then. I just didn't want you to get shafted like my brother. The only thing they did to repair the problem on his Camry was a pad of "dynamat" to cover the drilled hole..... I still think what they did was GAY in the first place.
Old 05-28-2006, 07:59 PM
Well I hooked up my friends amp to my car and the same thing happens so its not the amp its one of the wiring. I believe i have a short in my power wire maybe.
Old 05-28-2006, 08:46 PM
Night Owl
Leo C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeenyTymer69er &raquo;</TD></TR><TR><TD CLASS="quote">Well I hooked up my friends amp to my car and the same thing happens so its not the amp its one of the wiring. I believe i have a short in my power wire maybe.</TD></TR></TABLE>
if the amp won't work in either car, it's the amp itself and NOT the wiring
take apart the amp and look for any blwon circuits or shorted wires.
also is it making a funny smell when turned off?
Old 05-28-2006, 09:45 PM
wheelmanbg's Avatar
Default Re: How to tell if my amp is blown. (shutupnskate)
Sounds like you have a bad ground if both amps do that in your car
Try relocating the ground to your amp and see if that helps
Old 05-28-2006, 10:30 PM
02 accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wheelmanbg &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you have a bad ground if both amps do that in your car</TD></TR></TABLE>
What he said. Also, if you had a short in the power wire, your fuse would've blown by now.
Old 05-29-2006, 07:32 AM
I didnt use the same amp I used his amp to test it in my car. Yup I'll relocate the ground because I keep checking the fuze and its still not blown.
avaldez
Audio / Security / Video
11-25-2009 11:30 AM
Jdeno148
05-04-2009 07:03 AM
special_edition
02-03-2004 03:31 PM
intenseEK
23
12-17-2003 06:54 PM
Quick Reply: How to tell if my amp is blown.
