| Welcome to Honda-Tech! | ||
#1 |
when accelerating, my car starts to shake like i'm hitting small potholes in the road. The steering wheel doesnt really shake, I feel it more at the bottom of my feet. It feels worse when im making right turns, and doesnt really do it when making left turns.
UPDATE 4/28: -changed my passenger side axle -replaced passenger side inner tie rod -rebalanced tires -got an alignment ...and still nothing...I just bought a driver side axle and i'm gonna see if this helps... Modified by See Are X at 6:00 PM 4/28/2006
teamULTRASPEED '92 Civic hatch 327whp - 11.6 @ 120mph |
#2 | |
#3 |
also check the axle, if it is alittle broken, it will do that and also check if the axel nut is in tight
#4 |
could blown shocks have anything to do with it?
#5 | |
#6 |
| Garage is empty, add now |
6 and 12 sounds like balljoint.
3 and 9 is tie rod, it could be the inner or outer. Most likely inner. Take off the tire and move it on the 3 and 9. You will see the rod go in and out of the boot or the hub will move at the outer tie rod mount. That will answer your question as to which it is. I have a pass side outer tie rod NIB for a 5th gen civic. If u need it and it fits your application. let me know. |
#7 |
1995 Acura Integra |
wheel bearings have slop in them? Are you running stock diff, maybe it's taking a dump.
#8 | |
http://honda-tech.com/zerothread?id=1594932
#9 |
if you drove it not knowing that the boot was ripped it could have fucked with alot of other driveing componets
#10 |
Reaally? because a torn boot just sprays grease everhwere and allows contaminents into the axle. What could it possibley harm?
Also, unlikely, but are the tires still round? Mine would do this all the time, and it turned out to be a bulging tire. Which exploded violently on the highway. Yours doens't sound like that since i'ts just under acclereation turning, but something to look out for. Modified by red91sit at 10:40 PM 4/19/2006 |
#11 |
I just really hope its not my transmission. I'm probably going to try and replace the pass. inner tie rod next.
#12 |
update up top
#13 |
was teh axle bad at all? once i was short on cash and drove alittle to long on a bad axle and i busted my wheel bearing. not a fun ride. =P check the wheel bearings
-Kyle
F/S Thread http://www.hondamarketplace.com/show...8#post46773798 Zombie Build http://honda-tech.com/showthread.php?t=3023768 |
#14 |
Check the play in the inner axle joint. Could be that or maybe not?
#15 |
I changed the driver side axle and it kinda fixed the problem. It still shakes but really not that violent. Its probably time to replace my ball joints too.
Dunlop FM901's = very grippy tires Modified by See Are X at 7:16 PM 4/30/2006
| Tags |
| 92, accord, ball, car, change, cougar, honda, joint, lower, making, shakes, shaking, truning, turns, wnen |
