d16a8 head on a d15b2 block?
Old 12-02-2005, 05:03 PM
CroCivic90's Avatar
Default d16a8 head on a d15b2 block?
What needs to be done to mate these two together?
Old 12-02-2005, 05:19 PM
mattie_96's Avatar
Default Re: d16a8 head on a d15b2 block? (CroCivic90)
a mig welder and a grinder........
no really, taking out 2nd oil jacket from the dizzy side of the block(between cylinders 3 and 4)
after thats done, the other non wiring related part is changing to a new Y8 timing belt.
Wow I just realized you meant a8 not y8.....
Old 12-02-2005, 05:34 PM
CroCivic90's Avatar
Heh...i already have an A8 here waiting to get it's bottom end rebuilt...thought i'd have some fun with a DOHC head on a D15 block.
Anyone else has more info?
Just to make sure everyone knows what i'm talking about - D16A8 is just a european version of ZC. So, if anyone mated a ZC head to D15B2 - share some info!
Old 12-02-2005, 05:40 PM
zccr-xsi's Avatar
cant be done!cant put dual cam head on single cam block.if u can do it its porb. more time money and trouble then its worth.just go buy a dual cam zc
Old 12-02-2005, 06:04 PM
CroCivic90's Avatar
Default Re: d16a8 head on a d15b2 block? (vteckillenzc)
We don't get ZCs here in Croatia, only D16A8/9.
Can you explain to me WHY exactly you can't mate these together? What doesn't line up? Have you something to back it up?
Old 12-02-2005, 06:18 PM
Stunna MIKE's Avatar
ITS A duel over head cam head... you know with 2 cams.. and your trying to put it in a single over head cam block
Old 12-02-2005, 06:24 PM
zccr-xsi's Avatar
huh dude the a8/9 are the same as the jdm zc.
a8/9 are euro zcs.
dowl pins in worng place.head gasket it be to big for the block,not to mention your head would porb hang over the block a lil bit.dont even try.not worth messen up good head over something dumb.
Old 12-02-2005, 06:25 PM
CroCivic90's Avatar
Default Re: (Aaron EF9)
I don't get it...what are you trying to prove? 2 cams are in the head, head is mated to the block. What does block have to do with SOHC od DOHC?
Does this make sense: You use a 88 Acura Integra (D16A1?) Head Gasket on a ZC. It means ZC has the same holes on the head as the D16A1 head? It means that if you can bolt the D16A1 head on a D15B2, that you can bolt a ZC head on it too?
Can you bolt a D16A1 head on a D15B2?
Old 12-02-2005, 06:27 PM
CroCivic90's Avatar
I know, that's what i wrote a few posts up.
Old 12-02-2005, 06:28 PM
zccr-xsi's Avatar
Default Re: (CroCivic90)
hum? is this your frist time with hondas?
Old 12-02-2005, 06:30 PM
zccr-xsi's Avatar
ok go try it see what happens!
btw i highly doubt the head bolts with line up with the head.
Old 12-02-2005, 06:54 PM
CroCivic90's Avatar
Please, explain this:
http://thezcr.com/forums/showp...unt=7
Old 12-02-2005, 07:29 PM
zccr-xsi's Avatar
well i dont know.i know im on that site and they got good info.havnt seen that thread.try see what happens.i never thought i would work.btw if u read all the post they are al saying the same thing will it work? key word there is (SUPPOSED)
Old 12-02-2005, 07:30 PM
zccr-xsi's Avatar
try it worst that happens it u got to take it apart.what do u have to lose?
Old 12-02-2005, 09:12 PM
SVOboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CroCivic90 &raquo;</TD></TR><TR><TD CLASS="quote">Please, explain this:
http://thezcr.com/forums/showp...unt=7</TD></TR></TABLE>
The title says d16y8 head on a zc block. The y8 is SOHC, and then the picture has a y7 there, and then it says DOHC, that post doesn't make any fucken sense to me.
Old 12-02-2005, 09:19 PM
ludesrv's Avatar
Plain is simple man:
THE HEAD BOLTS WON'T LINE UP!!! THIS WILL NOT WORK! DO NOT ATTEMPT IT! DON'T WASTE YOUR TIME!
The head bolts are in different locations. Same thing goes for the SOHC D16A6, head won't fit. The ZC block is longer on the DOHC, now the SOHC would work, but your head won't. Leave it be. Besides, if you have a D15B2, you have DPFI, then you have to do the MPFI conversion. Just wait for the bottom end to come back and install it all as a complete package.
Old 12-03-2005, 01:58 AM
CroCivic90's Avatar
Default Re: (ludesrv)
Ok, thanks man. I guess i'll just wait and install the whole thing at once. I thought i could have some fun until i get the bottom end ready, but i guess i couldn't.
By the way, i'd have to do the MPFI conversion one way or another.
Old 12-03-2005, 02:00 AM
CroCivic90's Avatar
See, you have never tried to do it, but you keep saying it's impossible. That's what bothers me. You had no proof that it wouldn't work, you just heard others say it wouldn't work and you try to convince me it wouldn't, with nothing to back up your story.
Don't do that...
Old 12-03-2005, 02:02 AM
CroCivic90's Avatar
Default Re: d16a8 head on a d15b2 block? (SVOboy)
If you want to read the whole thread from beginning, go here - http://thezcr.com/forums/showt...80995
That link i gave is just the 7th post in that thread.
Old 12-03-2005, 07:26 AM
zccr-xsi's Avatar
lol dude u can look at the head and block and tell they wont fit together.there your ******* proof.i mean comeon this aint rocket sience.
Old 12-03-2005, 07:51 AM
crxnj's Avatar
Just made me think about this old post..Click Me
Old 12-03-2005, 08:08 AM
zccr-xsi's Avatar
Default Re: d16a8 head on a d15b2 block? (Mr.speaker)
hum?ok i guess.i would say it aint worth my time but i guess it can be done.how longs has it last and is it still driveable?turbo with nitrous lol i bet that bitch smoke like a ****
Old 12-03-2005, 03:42 PM
CroCivic90's Avatar
See dude, you talk about things you're not even sure of. I'm just saying - if you don't know, then say you HEARD it might/couldn't be done, but don't say it CAN'T be done.
Besides, if i had a block to look at, i wouldn't bother coming here and asking.
This is end of discussion for me.
efjones9
12-11-2009 02:33 PM
iluvmyef9
07-19-2007 11:16 PM
NirVTEC
10-18-2005 12:12 PM
dryhopsux13
12
11-04-2004 01:38 PM
Quick Reply: d16a8 head on a d15b2 block?
