best way to find boost leak?
Old 08-31-2005, 05:39 AM
skiwithcars's Avatar
Default best way to find boost leak?
i hav a turboed EP3 and i was running 5 psi for a few weeks(its supposed t obe at 7). so i assume there is a leak. and then a few days ago i repositioned my boost gauge and had to add 5 feet of hose. and i was running an open downpipe, so at the same time as i did the boost gauge repostioning i hooked mt exhaust back up. and now i have barly 4 psi when its supposed to be at 7. my exhaust manifold is missing 2 bolts but i dont see that that would have anything to do with it. any ideas of fixing it? i hav an air compressor if that helps.
Old 08-31-2005, 08:02 AM
dseries101's Avatar
Default Re: best way to find boost leak? (skiwithcars)
Check your hoses to see if there is any cracks in them. i had the same problem.
Old 09-03-2005, 06:27 AM
Default Re: best way to find boost leak? (dseries101)
yah ive checked all them, but i didn;t see anything
Old 09-03-2005, 07:14 AM
Jared's Avatar
i found a pvc cap the same size as my turbo inlet and used a coupler to clamp it to the inlet. tapped it with pipe thread and threaded in an air hose fitting so i could pressurize it with shop air on a regulator.
Old 09-03-2005, 08:29 AM
Default Re: (Jared)
yah ive herd of people doing that so i think im gona try it
mattmaine1991
10-21-2016 02:55 PM
ragethemachine86
09-12-2006 07:58 PM
turbotime
09-26-2005 06:22 AM
skiwithcars
08-31-2005 06:00 AM
G3NR8
08-19-2004 05:45 PM
Quick Reply: best way to find boost leak?
